F
I have an '11 Big Red MUV700 (P700 engine) that I've been working on fixing up. It had an extremely rough life before I got it. Currently, the machine overall runs great when it's running.
A few months ago I had the engine out and completely tore it down and rebuilt it. It got a new camshaft, followers, timing chain, tensioner, cylinder, cylinder head, piston, rings, gaskets, valves, valve seals, battery, starter, some sensors, and probably some other small things I'm forgetting. Basically, a fresh overhaul. Of course I made sure to set the timing and valve clearances. I'm no stranger to rebuilding small engines.
However, since I overhauled it, it has been hard to start when the engine is "cold". We have to give it about 1/4 - 1/2 throttle while cranking to get it to fire. No amount of key cycling seems to affect it. Once it does fire, it runs great. If you kill it and then immediately crank it back up, it fires up almost immediately. As the engine cools down, it gets harder to start. It didn't do this before I overhauled it so I'm almost certain it's something I did (or didn't do).
Since then, I have been going through a starter every couple of weeks. I can swap one out in about 10 minutes now. LOL! What happens is that all the cranking causes the teeth on the starter to chew down to where it won't engage anymore. I just carry a spare and the tools needed to make the swap.
Yesterday I decided to throw a new spark plug at it to see if that was the issue since I hadn't done that and it was terribly fouled from how it used to run. No luck with that being the issue, but this morning when I was working on it I pulled the new spark plug (NGK BK5RE-11) and the tip was as white as could be! Looks like I have a lean condition (engine doesn't overheat, no smoke, doesn't run rough at all). The plug has about 5 hours on it.
Since I had the plug out, I ran a compression test. I get 90psi every time (and calibrated my meter against a regulated air supply so I know it's accurate). The manual states 80psi is spec, so I'm a bit high here.
No MIL light (so I assume no DTC's, but I don't have an HDS reader).
Here's what I'm thinking the culprits could be, given that I overhauled it:
- I may not have timed the machine 100% correctly. If it's off, it's only going to be 1 tooth, MAYBE 2, off. I KNOW I was on TDC on the correct stroke when I timed it, but with the angle of the engine it might not have been lined up properly.
- I may not have set the valve clearances correctly (or they settled looser/tighter), especially the exhaust valves (which DO impact the compression/decompression)
- Probably need to clean the air filter, though I don't think that's the culprit
I'm going to get started on checking those two things, but wanted to get this out here and see what else I might want to look in to. Any thoughts?
