W
So I have read all I can find on here about removing the sway bars on my 500, but I'm not clear its the right thing to do for my intended uses so i'm hoping if i describe my uses you good folks can provide me a little better insight pertaining to my particular needs.
primary use is as a hunting rig, a lot of slow speed putting over varied terrain, on and off trail. Often encounter large road de-activations...either deep ditches or tall berms. sometimes animal retrieval requires crossing old logging blocks full of stumps and all manner of debris. currently with my dry box and gear I would say the is probably 100#'s on the back rack and in the future it will be used to pack up to 300#'s of critter at a time over all the above terrain.
currently running 26" rip saws on stock rims, contemplating 1.5" spacers on the rear tires for added stability.
so given all that is removing the sway bars a good idea for my applications?
also, if i do remove them...what would you reccomend the shocks be set to?
Thanks
Chris
Thanks
Chris
