P1000 Spare Tire
TexasJackKin
TexasJackKin
387
3,128
Dayton, NV
I've been trying to find a stock front tire and wheel for use as a spare for my P1K-5 LE, I'm starting to think I'll need to buy another P1K just to get a tire and wheel......
I've got patching and filling equipment on board, but worry about a pinch, or sharp rock split..... Has anyone found a source for a single tire and wheel?
Thanks for any help or advice
scdaf
25
67
central Washington
Bought one used off Craigslist from a fellow who had bought a set of four in order to get a spare, then, he put the other 3 up for sale. Got lucky, it was a deluxe wheel, matching my existing set. Paid $150, traveled 2 -1/2 hours each way. Considering my local dealer wanted around $250 for the wheel alone, I was happy.
TexasJackKin
TexasJackKin
387
3,128
Dayton, NV
WOW! I'd do that in a heart beat!
E
Ericthered
Eric The Red
271
522
Sparks, NV
Have two 12 inch spares in Sparks. Two rears, factory originals, steel rims with tires $50 each. Will have to come up to Reno to get them. Let me know if you're interested. Eric (775)440-1774
Robobrainiac
Robobrainiac
2,453
8,519
You can always go this route
TexasJackKin
TexasJackKin
387
3,128
Dayton, NV
I'm temped, my LE has 14 inch rims, so not sure about the diameter being "close enough" to get me home. Thanks though! That would be a good deal!
Reactions: ChadD and Lady01
Hillbillytnt
Hillbillytnt
517
1,897
Ky
My base model came with the 12” steels but I picked up a set of deluxe 14” aluminum that I’m running now. I use one of the front 12” steels for a spare. Both have 27” tires so I figure if I keep in on the front with the dif open it should get me home without a problem.
104,944
That steel front will work on your LE front and rear. I used one for yrs till i went with aftermarket wheels and tires. That would be your best bet for now unless your picky and want a deluxe wheel at some point.
TexasJackKin
TexasJackKin
387
3,128
Dayton, NV
If I'm reading @Ericthered correctly he has two rear steel tires and wheels, so that would only work for a spare on the rear. As I understand it a front can be used front or rear. I would prefer aluminum wheels just for the weight, but at that price I'd take steel, if I was sure it would work on all 4 corners...... Maybe someone smarter than me (Most anyone on this forum) can offer advice...... Thanks!
What's the probability of successfully slipping in a tube in the event of a non-repairable flat?
104,944
You are correct, only the front tire will work on all 4's. That's what I had. As for the steel wheel, I wouldn't worry about the weight. 9 out of 10 its only temporary and the weight difference (is not much btw and no comparison on the rear) won't be an issue at all even for the rest of the day or a few days ride. Inner tube, great way to save a tire that's still good and I have done this in the past. I wouldn't recommend doing that on trail cuz u have to break down the tire to do so and it can be kind of a Kamala Harris to get it inside and set. Id do that in my garage with beer lol.
Homer
Homer
Bad Decision Coordinator
1,010
12,744
GA
Running a rear tire as a spare on the front will severely limit steering. Get a front wheel/tire for all around spare.
Breaking/seating the bead for a trailside tube install will be difficult. That's one of the reasons to run beadlock rims.
Good luck.
bridgermgmt
60
143
Tahoe
A local shop here in Reno had suggested to run 4 of the same size on my old rig. Up til we sold the old rig, never had a single issue with steering components wearing out faster or any handling issues. Made carrying a spare on hunting trips real easy. We went up in width 1 size in front and down 1 in the back. Never had issues with traction or loss of manors. Was very happy with that set up. Most of the desert guys up here run in 4hi 90% of the time so I am sure that had something to do with not noticing the loss in rear traction. But with the right tire, pressure, and tread patch length, I think you wouldn't notice.
We just purchased aftermarket wheels on sale that matched the front.
We also tried the beadlocks but for the terrain and weather up here they were not worth the hassle. But they looked cool. Especially if your not sizing up a ton or adding much weight in the tire itself.
Reactions: Lady01
Amre2me2
Amre2me2
381
1,423
Colorado
You don’t need to haul around a spare tire. With any 8 ply tire (and some of the 6ply) tires, you can ride all day on a completely flat tire. The sidewalls are strong enough that you won’t damage them. Just keep a plug kit and a way to fill your tire. CO2 bottles work great. If you cut a sidewall you’re gonna replace the tire anyway.
If your gonna buy a spare to keep back at your rig so you can change it out, then that makes sense. Or if you’re gonna be going on a multi day trip, sure. But to haul a spare tire on your rig on a day trip doesn't make any sense at all.
Robobrainiac
Robobrainiac
2,453
8,519
I've got my spare mounted on a tusk tire carrier. I keep plugs, a sidewall slug, small bottle of slime, and 12v compressor with me. There are places we have gone at Drummond Michigan and never saw anyone. So we want to make sure we are covered.
IMG 20210708 200912
