Hello Folks
I have been a follower of this website for a very long time. I have used it often for learning important detail about the 1000 Pioneer. I recently had an issue with mine, a 2017 model. After riding for a couple of hours the speedometer would only register 0 and the unit would not shift out of 1st gear. I took it to the dealership as the unit is still under warranty. What the technician finally discovered, they kept it for 4 weeks, was that the speed sensor mounted on the top of the front differential had a poor connection to the wiring harness. Electrical issues that are sporadic can be very difficult to locate.
We had been black berry picking preparing to make jelly and I had been driving through a lot of brush and downed limbs just prior to having issues with the Pioneer. Apparently a limb had managed to find its way past the skid plate and stick stoppers and had loosened the connection. There is a speed sensor mounted on the top of the front as well as the rear differential. There is a small metal square cover over each one. The technician installed a new sensor and connector. Now all is well. I hope this post might save someone some head scratching if they have the same problem.
Edit:
I took the critter out for a ride this afternoon. After about an hour's ride the problem showed itself again. I will put it back on the trailer in the morning and take it back to the dealership.
One additional piece of information, when the speedometer starts to just show 0, after another 5 minutes of riding and the power steering alarm\light comes on. It did that the last time the problem arose before I took it in to the shop. The power steering works fine even though the warning light is on, the only difference is the steering may take just a tad more effort to turn the steering wheel.
I will keep this up-dated
Edit:
