P700 Spudders after water indecent
Brian1974
Brian1974
7
Illinois
Water down water down ...... So I got stuck in big water hole 700-4 and of course it died .....winched out dryed out started right up. Now though after getting it home changed oil air filter. She runs bit at first 25mph it spudders then 35mph. After running a bit it's fine. Any ideas ?
Reactions: sharp
67,234
Welcome to the club.
Sucks to sink it. The thing is a pig to pull out.
So, is it fine now?
This is common until you get all the water out of the system.
How is the fuel? Was the seat under? have you extended the vent tubes?
How was the oil? if contaminated, you need to change the oil more than once.
Reactions: Brian1974 and sharp
Brian1974
Brian1974
7
Illinois
So, is it fine now?
Winch was good easy pull,no milky oil yes water was up to dash, clean computer dryed added dielectric grease ,it's good after runs for few but at first like said it spudders, new to the whole sxs thing. Have Suzuki eiger been deeper never had this problem with it.thats why I was asking if anything else I need to do Thanks for replies
Sent from my SM-G930V using Tapatalk
Reactions: sharp
67,234
Yes,
The fuel has water in it. you need to pump it out.
The vent is under the seat. When it goes under it sucks in water as fast as it can.
This is also a common issue that we all recommend as the #1 modification if you drive in any mud/water.
Reactions: sharp and Brian1974
Motoman006
5
You may have water in fuel tank
Brian1974
Brian1974
7
Illinois
Just FYI thanks for the info I move my hoses
