P700 Squeaking sound
Brentc
Brentc
71
67
SE AK
I keep hearing a squeaking sound at the 5mph idle range. It sounds like it coming from the cage but I've tighten the s*** out of every bolt on the cage. Has anybody solved this? Thanks
Do you have the Honda hard roof?
I did on my 700 it was the source of the squeaks. I never did anything about it, but always wanted to. To me it sounded like it was coming from the clamps for the roof. I think there needs to be some grease put between the clamp and the plastic roof.
Let us know if you find anything out about that please.
Brentc
Brentc
71
67
SE AK
I'm still waiting for the hard roof to arrive. I can see the cage shake when accelerating from 5-10mph. I'm hoping when my glass windshield arrives that will help stiffin the cage.
Thanks for the reply I'll be lookin out when I install the roof.
Reactions: joeymt33
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Dang it's tough to diagnose a squeak but the most common on the 700 is probably the door latches or the dump bed mechanism. I would investigate these areas first. The way I'd do it is drive 5 mph to make it start squeaking, then hold your door open. Still squeaking? Have your wife open hers. Still squeaking? Pull the lever to dump the bed. Hopefully one of those actions at least identify a the source of the squeak. Then you can determine how best to fix it, @Lynn I think has a thread on how to stop squeaks somewhere. For the dump bed latch I think you just wrap electrical tape on the latch pin. I hope some of this is useful, good luck!
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Where the bed hook's put tape on it then put Marine Grease on the hook's should help.
Reactions: Tflynn
Brentc
Brentc
71
67
SE AK
Thanks! I had adjusted the bed but didn't think about the door latches. I noticed with the passenger open I wasn't getting the squeak only had enough time to adjust the latch before it started raining. I'll go for a spin again and see if I got it.
Brentc
Brentc
71
67
SE AK
It was the driver and passenger door latches.
