P700 Squeaky Pioneer
heybo
10
12
Mississippi
Has anyone had issues with constant squeaks? It worsens after turning and pressing the gas? I’ve checked for trash and looked for loose bolts but have had no luck. I hear squeaks near the right front tire and near the engine bay. Any help would be appreciated, it’s getting pretty annoying.
Reactions: Isaiah
Mudwing
Mudwing
36,959
306,563
The Mud holes
How many miles? Check the brake fluid level. If it’s low the fronts are worn. There have been some heat shields loose that cause a squeak. Tighten door stops. Without being there it’s tough to diagnose.
heybo
10
12
Mississippi
700 miles. I tightened the door stops and put tape on the bed so those are quiet. I’ll check the heat shield and brake fluid. Would the brakes still squeak while moving/ applying throttle?
Mudwing
Mudwing
36,959
306,563
The Mud holes
If you’re on the wear bar it will squeal. Mine last around 600-700 miles. I’m at 1700 miles and I change them like clockwork. Fronts only. If the fluid is low then it’s time for fronts. I just did the rears for the first time. The rears have two arrows/triangles on the caliper and when they line up it’s time for those. I’ll be doing fronts soon for the third time. I keep a spare set on hand. These are sintered. The organic lasted me the longest. I might go organic next. The organic feel like I have to push harder to stop. Happy to help. 😎🤎2014-2016 Honda Pioneer 500 700 Sintered HH Front Brake Pads
heybo
10
12
Mississippi
Just checked and fluid is good. Tried messing with the heat shield and couldn’t replicate any noise. I would prefer to take it to a dealer but the wait times are ridiculous right now.
Booey424
Booey424
New Haven, WV
Mine also squeaks. It’s more of a chirping sound. Mine is in the exhaust system somewhere. When I first start it cold, I can grab the muffler and it stops the sound
I have tried tighten all the fittings but they are so tight they don’t budge. The dealer said it was the heat shield
Mopower58
Mopower58
CST is the Best!
69,982
642,938
Crystal Springs,Ms.
@Mudwing keeps most of his moving parts muddied up so they don't make a noise! The Pioneer too!
Mudwing
Mudwing
36,959
306,563
The Mud holes
If you can pinpoint it, you’ll be better off. There are a bunch of things that make noise on these. 😉
41,748
The heat shields will be a constant with age/miles.
41,748
I’ve tried tightening every bolt I can find and it doesn’t help. Is there no fixes for it?
Try removing them temporarily to see if that is the source. The rear section seems to have been the source for all the ones I had.
I bought some header wrap and cut small strips to fit between the shields and exhaust pipe. You'd like to do the same between the clamps and shields...though that might be a bit fussy. You want no metal to metal contact if possible.
The stock clamps aren't strong and will strip of you tighten them too much. You might find some type of aftermarket automotive style that would work without the strips, but even off the shelf worm clamps will help, but they will need to be tightened occasionally. Also, make sure the overrun is bent away from everything, or you'll get noise from that.
I guess you could header wrap the whole pipe and ditch the shields completely, but there seems to be some disagreement on what that will do to the pipe itself.
Gator
Gator
The Most Unknown Member
2,474
10,381
Louisiana
I'm going to say this although it might not be what you want to hear.
It's an OHV. You are beating the crap out of it (it you are using it properly). It will never be quiet like your luxury car or even like your pickup. Sometimes I notice all the chirps and squeaks at first, but after 5 minutes of riding, they start to sound normal. Like a cat purring.
It's the 700 talking to you. She's happy. Listen to the sounds. Be aware if she goes quiet or the squeaks change, because she could be telling you something is wrong.
FlipKing
FlipKing
139
298
Same on the exhaust squeak. It didn't do it before I had an encounter with a stump. If I grab the exhaust it stops. It comes and goes and the engine vibrations affect it.
Booey424
Booey424
New Haven, WV
Yep, they make noise. Your ears will get used to it. Kinda like the folks who live by train tracks say.
I’ve had my ride since April. And the squeaky noise is getting more annoying by day.It is getting louder and Lasting longer the more miles I put on it
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Just wait a few yrs when the bushings start squeaking on the a arm. Funny sounding at low speed off camber like every little lumbering move is from some kind of cartoon. Lol
heybo
10
12
Mississippi
I think I’ve temporarily solved the exhaust squeak. At the top of the exhaust (closest side to the the cab) there is a metal plate that is close to the heat shield. That was rubbing the heat shield so I bent it in a little and no more squeak. I’m not exactly mechanically sound so I’ll have to take a picture in the morning to help my poor explanation.
JimmyA
JimmyA
1,644
5,503
Northeast texas
I have spent some time searching and looking over mine but to no avail! The motor and transmission is rubber mounted, the exhaust is secured with rubber hangers. I think if you could get some grease in the hangers, that may help.
