Has anyone put a steering wheel adapter on a p5 that allows a 5/6 bolt wheel to be mounted?
Peter_72 Well-Known Member Supporting Member May 31, 2020 792 6,526 93 Louisiana Ownership 500 Sep 13, 2022 #1 Has anyone put a steering wheel adapter on a p5 that allows a 5/6 bolt wheel to be mounted?
Remington Deputy Fife POIDH Enforcement Officer Lifetime Member Supporting Member Jul 24, 2016 18,344 104,592 113 Michigan Ownership 1000-5Talon X Sep 13, 2022 #2 I think all Pioneers are the same in that dept. @CumminsPusher has done it to his rigs Reactions: Peter_72
Neohio Beast of the East Lifetime Member Supporting Member Club Contributor Dec 22, 2016 13,306 64,446 113 Painesville Ohio Ownership 1000-5 Sep 13, 2022 #3 If i recall, you need an adapter that fits a 92-96 Prelude. Buy a good one. I bought a cheap clone and it isn't worth the pot metal it is cast from. Buy a good one like this. NRG Innovations SRK-110H Short Steering Wheel Hubs, black https://www.amazon.com/dp/B0026VF4SO/?tag=sxsweb24-20 Reactions: Rdrcr, 500oneer, Peter_72 and 1 other person
906UP Well-Known Member Lifetime Member Supporting Member Club Contributor Jul 6, 2017 12,949 120,555 113 da Yoop Ownership 1000-3Talon X Sep 13, 2022 #4 I used a dragonfire set up on my Talon, it will be the same for the P5, they use the same spine Reactions: trigger, 500oneer, Peter_72 and 1 other person
Peter_72 Well-Known Member Supporting Member May 31, 2020 792 6,526 93 Louisiana Ownership 500 Sep 14, 2022 #5 Thanks guys! I’ve seen them on Talons and P1000’s but wasn’t sure if the steering shafts were the same. Reactions: Rdrcr
