P500 Steering wheel horn button
hondasrule
hondasrule
50
195
ontario
Wanted to share how to install a working horn button in original p5 steering wheel using a home made clocking spring. Works perfect. 1AC2B715 C5A4 4302 94F6 9AE3D2FE99BC 411C4AF2 B56F 4DD1 96CB 1AD43E739EA2
5A748C81 86EC 4965 89C9 FD23488DFD30
0AE3E597 DB22 4D39 951B 3311D48844D3 5E8B5B34 DD8A 4D39 BB11 B8F2BF7C5F9F 3E44FF7B 5990 48A2 BAC1 458E8AA5812A B7EC7F6A FEB6 40C0 A7A4 0CD0B41C3A96
E211FBCA F43B 47F4 AFEF 661D2CA2611D
6CD3116E C61B 4607 8221 1FF31074A19D
Mudwing
Mudwing
36,959
306,563
The Mud holes
320,693
hondasrule
hondasrule
50
195
ontario
This is a mod I definitely could use. What parts did you use?
I used stainless tig weld wire. Wrapped it around 1-1/2 tubing 3times. Used a short peice of 1-1/2 schedule 80 pvc. Machined inside slightly to fit over column. The contact plate inside wheel is stainless light gauge sheet metal. Made a few isolation washers out of plastic containers. Drilled a small hole through wheel for wire to go amd make contact to plate and spring. Cut hole in p5 Center cap and silicon the new 2in horn button in. Purchased horn button and wolo horn off amazon. Wired through std 12 v relay same as most cars.
I can send more pics and info if you wanna try it.
I love having the horn on the wheel. Will try to upload a video shortly.
Cheers
hondasrule
hondasrule
50
195
ontario
Cheers
Pioneer 500 front diff locking spool -all4p5”
