RECALL - Power Steering Joint, 2017-2020 P700, 2016-2020 P1000 EPS Models Only
HondaTech
Only affects models with Power Steering
Just dropped sometime this afternoon
No info on a fix or inspection just yet. Only mentions Steering Joint B in the title.
More information coming Friday September 4th. I will post any more information pertaining when it's available.
@Hondasxs Feel free to sticky when the info becomes available
1000 700 stopsale
Sorry for not getting the info on here yesterday.
  • ml.remaw05a.mtb_17596_sxs1000_sxs700_steering_joint_b_safety_recall_final_2008.pdf
43,070
Which one is B?
66,871
So what’s the problem, will steering joints fall apart? Just get loose and sloppy? Thanks @HondaTech for the heads up.
Sounds like they were not seated/installed correctly.
The same joint is used on the NON-ESP so that rules out it being a joint problem.
Spoonbill
Spoonbill
226
272
East TN
Thanks for the heads up. Will keep an eye out for the recall
Really appreciate the advice . Please keep us appraised.
Dmillerforhonda
7
Lott,Tx
According to pioneer page on Facebook the shaft is sliding of because bolt is not tight enough,if I understand it right.
Reactions: fac8828 and Biteme
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
Thank you for the clarification.👍
Reactions: Biteme
Muhkan51
Muhkan51
Love this thing!
32
41
Louisiana
Thanks for the info!
Ridge-Rabbit
Albany, Ohio
Funny....I know my steering wheel was no longer centered after first ride on new 2020 1000-5 Deluxe.....wonder if related. Thanks for the heads up!!
Reactions: Isaiah and Biteme
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
The steering wheel on my 19 P700-4 has been off since the second ride so I will check everything out.
Definitely appreciate your heads up.
