^^^^^^^^^ what he said!!!!Soap, water and a micro fiber towel
I have been recommending plexus since I use it on my plane. I couldn’t figure out why Super ATV said not to use it. Your explanation was very good.Okay, there's some conflicting advice going on! Dunegod and Rayger143 are spot on . . .
For Plexiglas (trade name) acrylic, plastic cleaners, polishes, and products such as Novus are fine. With acrylic, you can polish out (remove) fine scratches with ease, (and deep scratches with the proper grades of abrasive), so most small aircraft windshields are acrylic. Acrylic is not used for UTV windshields as it is not impact resistant and will crack and break on impact.
We are mostly dealing with polycarbonate (trade name Lexan) which You should not use polishes or plastic cleaners to clean. Polycarbonate windshields will often have a hard coating to help prevent scratches. Using fine abrasive polishes can slowly remove the hard coat, exposing the much softer plastic and making it more susceptible to scratching.
See SuperATV's excellent page on this:
The UTV Windshield Buyer's Guide
Pretty much just to cover our butts if one of the products used had a chemical reaction with the poly or our hard coating chemicals. Some do. I've seen some discoloration with a couple products. If Plexus works, hell yeah! I've always just given it a few layers of Pledge every couple rides whenever its needed.I couldn’t figure out why Suoer ATV said not to use it.
That'll work perfectly.Super ATV what’s the best method to clean window? Pledge only? Soap and water with microfiber? First time cleaning it so don’t want to mess it up.
That should be ok.What about using soap, water and vinegar for removing water stains? Is vinegar (water mixed in) bad for that type of windshield?
And a handful of gravel... 🤣I just use a Brillo pad on mine.
Regular or lemon scented…..🤔I've always just given it a few layers of Pledge every couple rides whenever its needed.
Thanks for the input. By the way this flip up windshield is a Great product.Pretty much just to cover our butts if one of the products used had a chemical reaction with the poly or our hard coating chemicals. Some do. I've seen some discoloration with a couple products. If Plexus works, hell yeah! I've always just given it a few layers of Pledge every couple rides whenever its needed.
Always go lemon scented. Adds 2 HP.Regular or lemon scented…..🤔
Thanks man!Thanks for the input. By the way this flip up windshield is a Great product.
