P1000 Super ATV rear windshield with back up lights
Jmalec
  2. Do not currently own
2021 1000-5 with back up light kit installed on top rear roll bar. Will the super ATV rear windshield fit or will I have to remove the lights?
bumperm
bumperm
1,931
6,829
Gardnerville, NV
Not sure I can help without pictures of your backup light installation. I have the SATV rear windshield and mounted backup lights above that on the rear down slope of the stock roof.
Reactions: Robobrainiac
Jmalec
Here are a few pics. I pretty sure the rear window should tuck up under the roof and those lights will be in the way.
IMG 0263 IMG 0262
Reactions: ChadD and Remington
283,544
View attachment 389910 View attachment 389911
You will either have to:
A: remove the lights.
B: notch out the SATV plexiglass where the light clamps are.
C: mount the light to the roof plastic.
D: mount the lights to the rear plexiglass ( not recommended)
Reactions: ChadD
bumperm
bumperm
1,931
6,829
Gardnerville, NV
What @JACKAL said with a minor but important exception. The SATV rear windshield is not Plexiglas (or plexiglass), which is acrylic plastic. Rather they, like the plastic front windshields, are made of polycarbonate (Lexan being one trade name). The differences:
Acrylic: Better light transmission than glass! Cheaper than polycarbonate. Can shatter into dangerous shards on impact or crack when drilling or cutting if care is not taken. Holes are typically drilled oversize to prevent cracking from thermal expansion etc. Can easily polish out minor scratches.
Polycarbonate: Bulletproof (literally, when thick enough) so impact resistant and safer in an accident, can be cold bent in a brake. No problem drilling, sawing etc. Scratches do not polish out easily if at all. Softer than Plexi, so is sometimes "hard coated" for scratch resistance.
The only pic I have showing the rear lights. The are actually a little lower than they appear, and below the top of the roof line. You can see from the way the rear windshield mounts that OPs lights gotta be moved.
20220428 223430
SuperATV
SuperATV
1,784
13,125
Madison, IN
www.superatv.com
You may have to adjust them if the clamps are in our clamp locations, but I'm betting you can make it work pretty easy. It wouldn't take much to mod the windshield if you needed to notch it, but you may not have to as long as the light clamps aren't in our windshield clamp locations.
Reactions: bumperm and JenElio
283,544
How did you ever make out? I Have the rear flip up windshield on and just ordered the lights and kit to see alil better at night. Adam
I'm running the backup light with the SATV Flip up rear window. Work's 👍
Screenshot 20250128 151009 Gallery2
  • Love
Reactions: SuperATV
