SuperATV EZ Steer EPS problem
Prntckt
Prntckt
1,104
7,710
Altoona, WI
I installed a SuperATV EPS kit in my Talon X4 about 18 months ago, and have been happy with the upgrade. Last fall, I noticed some sloppiness in the steering and found the splines in the middle u-joint had worn smooth. SuperATV sent me a new steering shaft and that took care of the problem. I loctited the fasteners to avoid future problems. I am again starting to notice looseness again in the steering, and intermittantly the steering pulls hard to the left. Alignment is good and I dont see any issues with front end components. Has anyone else ran into this problem, and what did you do to resolve it?
  • Sad
Reactions: CID
906UP
906UP
14,874
141,348
da Yoop
Cant say I've had the problem but I'll be checking mine. Like you, it's been installed for about a year & half, I'll report back with my findings
Reactions: Smitty335 and CID
Bad_bowtie
Bad_bowtie
Huge member
2,567
15,859
East Tennessee
I need to check mine. I've had the Superatv steering for almost 2 years. It's had some slop in it for awhile, but I've kinda gotten used to it and forgotten about it.
ScottJ24
ScottJ24
76
212
Cresson, TX
Just as a matter of practice I always replace both the bolt and the nut if anything gets loose. Replacing just 1 of them is asking for looseness again. I would expect that you will fund that the shaft or the u-joint is the problem. Always replace both parts. That way you have new splines fitting properly. JMO.
