If you own one....How's it working out for you?.........Honda Pioneer 500 Scratch Resistant Flip Windshield
I like mine as well. Seems like I have to clean it all of the tine for clear visibility.If you own one....How's it working out for you?.........Honda Pioneer 500 Scratch Resistant Flip Windshield
Someone on this site had used "Plexus Plastic Cleaner" with good results.....I found it on Amazon...https://www.amazon.com/dp/B00092CKN4/_encoding=UTF8?tag=sxsweb24-20I like mine as well. Seems like I have to clean it all of the tine for clear visibility.
I just installed this windshield on my 2017 P5. I haven’t got to take it out with the windshield installed yet but I like how it is made and looks. I mounted it a little high but removing the hood is still tough. Any suggestions for easy hood access? Would not think twice about buying again.
Mine was suppose to came in the other day, only problem was Amazon sent a 5 Drawer Dresser instead so I had to re-order and it won't be here until Monday.
I planned on doing some mount modification on the lower shield by fabricating new brackets for the roll cage and adding a couple of hinges https://www.amazon.com/gp/product/B0721K827M/?tag=sxsweb24-20 the hinges may also need modification to. If you want I could post some photos when it's compete.
That would be great. I have been thinking that if the bottom would swing out some it would allow the hood removal. I mounted mine as high as i could leaving about an inch of clearence but just need a liitle more. I can get the hood off but not easy. I was looking at doing a mod but had not put a lot of thought into it yet. Would love to see your solution. I also got mine from Amazon prime.Mine was suppose to came in the other day, only problem was Amazon sent a 5 Drawer Dresser instead so I had to re-order and it won't be here until Monday.
Well I got the re-ordered windshield today...problem is it was for a Yamaha Wolverine so once again it's got to be shipped back......I'm done with windshields for now....time to move on ...later folks.
Thanks! This looks like a good solution.Another member of this site posted this Modification.....if you hadn't seen it I thought I'd share t with you.....looks pretty simple.
P500 - Super ATV Windshield Modification
