P1000 SuperBee build
TheHoover
TheHoover
221
694
PNW
hondasxs.com
I've honestly not seen the vent lines ran into the air intake. Depending on how deep you plan on going..... I've got all mine run up between the front seat and dump bed, then slightly faced down to avoid water from getting in from washing, rain, etc.
The water doesn’t look deep...
2-3 feet hopefully is the deepest I get myself into. But I’m the type that doesn’t turn around.. I’m also the type that wash’s my toys. I’m worried about that too..
I also thought about building some kind of filter box that I could route all the vent lines too..
Reactions: CumminsPusher
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Modifying something like this. A central location for all lines.
1539B1AE 39B8 4719 B823 9E2708DDC587
Reactions: Rambo
TheHoover
TheHoover
221
694
PNW
hondasxs.com
This winter I will be doing the following upgrades:
- Finish vent line extensions.
- Dual battery setup.
- Front bumper light pods and bar.
- Dash plate with switches.
- Engine heat management fans: 2, 4” fans.
- Under dash storage.
- A ROPS storage bag of some sorts.
- Maybe some other light mods
- Rear lights.
- Whore lights.
- Rock crawler lights.
That’s all this winter. Get an actual radio and winch installed next summer. Fun stuff!
Reactions: Remington
TheHoover
TheHoover
221
694
PNW
hondasxs.com
I forgot, I added some ROPS handles. I had to pick some to work with the nuts from the netting. I like these enough that I’m adding two more for the rear. Amazon specials, held up great so far.
0941DA6C BD62 43E2 A063 E7F058EA6553
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Got the under dash storage from Honda, and the door cup holders, NOT from Honda. These ones are a little bigger. Happy with all of it, seems well made.
Also got 4 pods and switch for the front bumper. Just waiting on the rest of my dual battery setup to trickle in.
30E92A6D 65A5 4E38 8200 9800F4C39AC9 B9E3C807 456B 4663 A8C1 453ACFB1CE81 CACB032A 452E 4275 96C8 F4DF7C2A53A2 50E4C76C 6DCD 4098 A270 6431EC2C01F3 AF447E26 110D 4BFD 8059 434034CBA45D 7963EF59 2658 4492 8198 C17FE09A0DAE D657284F F7CD 41DE 8DB5 A28EFCC14277
TheHoover
TheHoover
221
694
PNW
hondasxs.com
View attachment 99059 View attachment 99060 View attachment 99061 View attachment 99062 View attachment 99063 View attachment 99064 View attachment 99065
I have some stainless steel at work that I’m using for a switch plate on the dash. I’m also going to use these beauties to mount it.
420AB1D9 2835 42F3 87CD 59090765A9A1
TheHoover
TheHoover
221
694
PNW
hondasxs.com
I was also going to say the instructions say to use a 3/8” drill bit for the under dash storage and cup holders.. I used a 5/16 for a Much tighter fit. FYI.
Reactions: dnjones161
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Got my pods on. I had to pull the front bumper out a little to get to the bolts on clamps. I’m still waiting for all the components to arrive for my second battery setup. Then I’ll hookup power and set the “aim” of the lights. I’m thinking about having the two lower pods point straight forward and the upper pods turned out slightly.
6D0BED33 6FE6 4226 A7AC DF11FBECD468 7322DCE4 B101 456F A903 853D36A77753 689F9D6C D2FD 43F0 9CEB 6913906D6905 0F65177F A688 4847 AF87 739A84C19486 96339100 9FFF 4D78 9D0B 5AB041B91625 0BF78FDE FE25 45EF B744 2A37E07DB81A
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Job done. I extended the gas, rear diff, and trans. The front diff was good for me, so was the cable box(what’s in there? What is it venting?). I ran gas line tube and thick, chem resistance poly tube for rear diff. Everything is ran nice and tight. Along same routes as factory wires/cables. Spent some time and did it right. I’m happy with how it turned out. I don’t plan on getting in water deeper than 2-3’ max. This accomplished that.
B12453BC EC8A 488D A225 F6F5FA59706D 85EA55E5 6E35 42B4 BD59 B071EEC8B258 2BA53BFA 1651 4966 8FD5 90B4D8EEAFBA 978931A6 E2EF 4040 96B4 9D39A829F612 C839DF3C 7D20 40D0 B8A5 B7104B9D4C0B 262F0D07 B4A5 4EA6 8834 5F360492E392 3A778621 B9B7 4644 8174 8034E0B917FA 86FB666B F254 4495 B39B BB6D89F133C2 42649998 08AE 4709 80D5 0B2330E957DA
TheHoover
TheHoover
221
694
PNW
hondasxs.com
We have lights! I still need to clean up the wiring under the hood and find a spot I like to mount the Tru, Stinger and fuse box. I’ll start making my switch board inside the cab. Side note: the wife decided on the yellow, I was on the fence and it grew on me, I love it. The wife also decided on the color blue for inside the cab(switches and whore lights), I wanted green. Now that there’s power to it, I like the blue! Haha. Women.. Anyways, with these pods, I get damn near 180degree coverage, which is what I was hoping for. Any objections to using good 3M double sided tape on the fuse box to stick to the top of battery??? I’m not sure where else to put the damn thing. Haha. I have a spot in mind for the Tru, Stinger and relays(not like in pic.).
36560CA8 1D04 43C6 8C57 10B88F8209B2 D6B790CB 949B 416E A212 477693BAFDF2 41282BDC 4776 4DCE B610 AB054E6760DC 4BD3EBDD 3533 418C AF11 9DA34B58DB65 36376D94 3C28 4CBA A001 542B22E1A944 5D4972B3 6EB5 45DE 80B5 E5AEFC92CADC
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Cab heat cooling fans installed! Got a little more involved than I thought but that’s part of the fun right?. So I’ve got everything (except radio) plumbed in. Now we gotta clean s*** up under the hood and make it look professional. That’s tomorrow’s project. Gonna keep the floor boards off until I can line it with Thermo-Tec. Going to do the rear floor boards and bottom of seats too. Then I gotta make the switch panel. It’s slowly coming together! There’s a good breeze coming out the rear when the fans are on! Paired with Thermo-Tec, cab heat should be fixed!
EE1741F6 378E 46E9 A923 CC125017AEC1 D32A7AF9 4DA2 4047 8C87 B5CBF787CB71 447A3660 5805 427E 9841 A18FCFF8001E 7DBD468C A238 4D1B 8F8C 94D564869CA7 DAAC7B14 C227 4222 A4AA 3349FB089AE6 EC246320 9980 47BD A9CA 61F4DA202DAC 61E6F390 E287 4F33 AEBE 10ED1E380D8F
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Finalized the dual battery setup. I think it turned out good. Switches and power gauge is just hanging out the dash. Hopefully find some time tomorrow to start making that. Used:
TruAM isolator kit.
Stinger relay hooked to switch.
Mighty Max battery.
BlueSeas fuse panel.
Mictuning & 50 caliber racing rocker switches.
CCB5E390 458F 4309 A0D8 476B90DFB186 8A476502 D683 46F5 A010 1ED397521E5F 78A6EA6D FE56 4F6C ADB8 B4F0A39BD601 6F0B5BD2 B48C 46EB A4D1 25B1900C63AE
Reactions: Rambo and trigger
Similar threads
Replies
Views
521
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
