P700 Surge in Speed
DAIII
DAIII
70
92
New Hampshire
This is odd - Today while riding I noticed the speed flashed and the engine sounded sputtery. I then said Opps my seat belt- added it and it still did it. I didn't turn it off or on- is this normal? What does it mean?
Reactions: sharp
208,013
How old are you? Sure you weren't having hot flashes, HA!
Reactions: DAIII
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,601
Ridgeway, SC
Likely you were in manual mode and hitting rev limiter. Neighbor did the same thing ....
If he’ll think about it, Smitty will know who I am talking about
Reactions: Tuco69
208,013
I think I do, wish they were my neighbors, had a blast with you and them at The Take Over!
70Bones
70Bones
888
3,779
New Brunswick Canada
I've had that happen in my P500, I found it was the seatbelt limiter kicking in. I removed the magnet from the seatbelt receptable, 5 minutes, and it hasn't happened since. I got tired of unhooking the seatbelt and jamming it back in hoping it would work, it always did, but still a pain in the buttocks.... :)
jinx
jinx
565
528
I’ve hit the seatbelt limiter once where I had to shut off and restart the rig to get it running right
DAIII
DAIII
70
92
New Hampshire
Yes, that worked! has plenty of power again. (left them buckled) did I read right I can disassemble the buckle and remove something to avoid this issue? any write up?
Mudwing
Mudwing
36,959
306,563
The Mud holes
If you’re in drive without your seatbelt on and put it on while rolling, it will bounce off the seatbelt limiter. Do what jinx said and restart to clear or just stop and shift to neutral with your belt on. As far as jumping the switch out, there is a thread about it. I also saw another thread about what happens when you don’t wear your seatbelt and have an accident. I wear my seatbelt every time I ride and won’t jump out the limiter.
Reactions: swsebek and lee
DAIII
DAIII
70
92
New Hampshire
Oh awesome! I just pulled that magnet out- I use this rig on my property and ran down my long driveway at 11mph and it sputtered and freaked me out, especially if you followed my leaky coolant 'blue fluid' issue. I always use the seat belt (SXS and Vehicle) and NH is a no seatbelt, no helmet and nope you don't need car insurance! - but my brain won't remember the sequence of N before the buckle. I'm a buckle on the roll kind of person. HAHAHA
Thanks everyone!
Reactions: Farmer and Mudwing
DFABane
DFABane
21
34
My P500 will do that if I don't buckle up. I found that with mine I am forced to come to a stop, take it out of gear and take the belt off and then put it back on... Everything is fine then...
Reactions: swsebek and Mudwing
