Planning on doing some auxiliary electrical mods to the Talon but I'm at a crossroads. I have a SE X4 so it came with the factory switch plate kit and 5 possible spots for switches from factory. I think 5 might not be enough for future upgrades (dome lights, i4wd bypass, compressor, lights etc) and so I'm looking at ditching the factory setup and running a 8 gang aux beam switch panel. It also seems more cost effective after factoring in pigtails, back-lit rocker switches etc, while
leaving me more room to expand. What are the thoughts on this? And since electrical is a weak point of mine I'd like to know if the aux beam can be made to plug into the factory harness or does it have to be run back to the battery as if you were installing it on a talon that wasn't prepped already for the factory switch panel.
My bad if this has been covered already or there is a write up floating around. Couldn't find what I needed searching.
