Switch plate vs aux beam
Domin131
Domin131
41
282
80537
  1. Talon X4 LV
Planning on doing some auxiliary electrical mods to the Talon but I'm at a crossroads. I have a SE X4 so it came with the factory switch plate kit and 5 possible spots for switches from factory. I think 5 might not be enough for future upgrades (dome lights, i4wd bypass, compressor, lights etc) and so I'm looking at ditching the factory setup and running a 8 gang aux beam switch panel. It also seems more cost effective after factoring in pigtails, back-lit rocker switches etc, while
leaving me more room to expand. What are the thoughts on this? And since electrical is a weak point of mine I'd like to know if the aux beam can be made to plug into the factory harness or does it have to be run back to the battery as if you were installing it on a talon that wasn't prepped already for the factory switch panel.
My bad if this has been covered already or there is a write up floating around. Couldn't find what I needed searching.
Dirtstiffs-1000
Dirtstiffs-1000
1,559
5,684
hondasxs.com
I'd go Aux Beam style if I were to do it over again, for sure.
Simplifies wiring, neat and organized.
20220917 175120
63,963
Do you plan to go with a Dual battery?
Aux beam is by far much easier. however, its customization options are limited for the more advanced installer. The 80 is just a on/off box, the 800 adds more functions such as strobe and momentary along with RGB panel color choice.
If you want simple, you can't beat a system like this. There are several on the market similar.
For the Talon, you just can use the + and - that is already run upfront for the battery.
After that, its just hooking the trigger wire to the blue connector, and its almost installed.
AuxBeam includes an 80a main fuse, I would install that, so that's 1 extra step but its easy.
I installed mine near the steering column. My next machine will be right under the hood so I can access it without tools.
JumptChaneAZ
First question, how many amps is the output of the oem Talon stator? Searched high and low and was never able to find the answer. My Google Fu must be weak.
63,963
Talon 1000 = .7kw = 58 amps @5000rpm
Pioneer 1000 = .6kw = 50 amps @5000rpm
Pioneer 700 = .45kw = 37 amps @5000rpm
Pioneer 500 = ??
JumptChaneAZ
Pioneer 500 = ??
Excellent. Thanks. I had the 58 in my head from my aux battery install quest, but couldn't remember where I got it and couldn't confirm it. Why did I come in here again?
Domin131
Domin131
41
282
80537
  1. Talon X4 LV
Dual battery wouldn't be an issue if I had to do it. Looks simple and fairly inexpensive. And I'd be going with the simpler 80 switch panel. I have no need to have all the light options the 800 has.
Reactions: Remington
107,087
If u want a challenge and something to call your own and want to learn a new volger language, then do a switch plate. If u want super easy kinda plug and play, get the Aux beam.
I have the Switch plate do it yourself i made in My Pioneer. Its unique and something I did myself and can call my own. Its was early days in the forum sort of speak. Changed it multiple times and still doing changes today. Would I do it again? Tuff question. 50/50 cuz I hate electrical circuitry even tho, I do alot of that $hit at my job.
I did the Auxbeam in my Talon and loved the easyness and the quickness to set it up. just hate the key on only power up with it. Would I do that one again? You bet your ass!! ;)
107,087
If your doing any accessories, do the second battery and put them all on it. You wont regret you did in the long run. The price to do that is a small price to pay compaired to the issues you may incur latter having them all on the main
Scoop
Scoop
4,226
15,820
  3. Talon R LV
If he changes his mind and wants the 2nd battery later on, he'll wish he had done it BEFORE he wired all the other crap up. :)
5,047
22,618
You’ve already mentioned that 5 additional circuits might not be enough, that alone suggests that you might as well install the second battery first. If a winch is in your future, you definitely want that pulling off an aux battery, not your starting battery. I was put off by the expense of the AuxBeam but looking back at how much I spent on aftermarket items, it would have been a drop in the bucket. :oops:
I can’t answer the question of whether you can power the AuxBeam from up front or have to run back to the battery other than - the battery is already extended to the front to power a winch. You have to connect the leads at the battery though, they’re tied back, not connected.
Domin131
Domin131
41
282
80537
  1. Talon X4 LV
I'll be going with a auxbeam style switch. Crossroads 3D makes a really slick flush mount plate for the auxbeam/switch pros that I'll be running in place of the factory switchplate. So that's settled
I already have the factory warn winch on the talon so that's that. I guess I'll plan on doing the dual battery setup right off the bat to save a bunch of cursing in the future. Since I'm adding that to my list which dual battery setup do I go with? Looks like there are 2 in the club store and reading about them the PEP trueam sounds better? Now do I go lithium battery or lead?
Thanks for all the input fellas
Domin131
Domin131
41
282
80537
  1. Talon X4 LV
Aux beam with Trey Brock's 3D printed mount. It sits right in front of the shifter out of the way and easy to use. Also keeps your cubby open to store your snacks.😉
That one is cool but I'm going to run the crossroads 3D plate. Mounts right underneath the cluster where the factory switches go. Better view of the switches too I'd think being up higher.
Screenshot 20230301 080047 Chrome
Reactions: Smittyp
Kadert21
Kadert21
20
124
They are actually pretty easy to see and if you use this one you could also run his tablet mount up top. Its your rig you do you. Just showing options.
20230102 210343
