Hello everyone, already 6 months I cannot deal with 83 error, tried new oil pressure sensors, checked wires, whore wiring cables, ground connections(2 on engine, 1 joint under driver seat) checked for corrosion, bad or loose contact, low voltage battery, nothing helped, does anyone have other ideas what to check, here is the video with error and clutch temp indicator.
