i4WD is different than the other ECU's and on top of that, there are no "14-" codes (goes from 12- to 15- and skips right over 13- and 14-)...
Shows how much I know. 🤷🏻♂️
If you don't mind full time 4wd I'd pull it apart and figure out a way to lock it up permanently.It’s seems crazy to me the clutch assembly is 900, and only 1300 for whole diff
You have the luxury of that fancy Honda MCS so you don't have to "know" like the rest of usShows how much I know. 🤷🏻♂️
You have the luxury of that fancy Honda MCS so you don't have to "know" like the rest of us![]()
If mine is broken like I think it is ill be pulling mine apart and locking it up permanently. My Talon is strictly for race use on dirt so I don't care if it's not 2wd anymore. Your needs may differ...
*My front diff clutch worked fine previous to the little accident I had late in the race season that tore it off the diff housing. It did not just quit working like OP's did.
We are gonna need pictures of that....We tore one apart to see whats inside and making it locked permanently would require a shaft to be machined.
Its honestly amazing that the magnet and a plate is all thats transmitting the drive force to the diff. It almost doesnt seem like it would work once you see it in pieces.
Oh, I don't know, maybe this had something to do with itComplete front diff came in, and had time to pick it up. Pushed snow for 30 hrs, taking today off work. Pulling front diff now. Will see how original clutch and diff look, but trying to decide if I should swap the whole unit, or just the clutch. Not sure if I want the locker or not now. Coincidence maybe, but never any issues till put the locker in
Sounded sketchy with the turbo at the rev limiter doing cyclones 😆
Oh, I don't know, maybe this had something to do with it?...
It was already broke at that point, I’m sure it didn’t help 😆Oh, I don't know, maybe this had something to do with it?...
