Talon differential won’t stay engaged
SLOWPOKE693
SLOWPOKE693
1,973
7,691
Somewhere in Texas
It’s seems crazy to me the clutch assembly is 900, and only 1300 for whole diff
If you don't mind full time 4wd I'd pull it apart and figure out a way to lock it up permanently.
If mine is broken like I think it is ill be pulling mine apart and locking it up permanently. My Talon is strictly for race use on dirt so I don't care if it's not 2wd anymore. Your needs may differ...
*My front diff clutch worked fine previous to the little accident I had late in the race season that tore it off the diff housing. It did not just quit working like OP's did.
Reactions: All_Moto
SLOWPOKE693
SLOWPOKE693
1,973
7,691
Somewhere in Texas
Another note..... I have been running an I4wd bypass switch since I built the car. @Hondasxs made me a custom harness that used the stock switch to accomplish the task. Car has no idea it is in 4wd and the indicator light always said 2wd. 😎
You have the luxury of that fancy Honda MCS so you don't have to "know" like the rest of us :)
True, not gonna lie sometimes i forget how to pull codes the manual way without looking in the book first. The MCS is a magical thing occasionally.
  • Haha
Reactions: TripleB and Adam490
We tore one apart to see whats inside and making it locked permanently would require a shaft to be machined.
Its honestly amazing that the magnet and a plate is all thats transmitting the drive force to the diff. It almost doesnt seem like it would work once you see it in pieces.
  • Wow
Reactions: CID
SLOWPOKE693
SLOWPOKE693
1,973
7,691
Somewhere in Texas
Another note..... I have been running an I4wd bypass switch since I built the car. @Hondasxs made me a custom harness that used the stock switch to accomplish the task. Car had no idea it was in 4wd and the indicator light always said 2wd.
We are gonna need pictures of that....
I have a welder and am not scared to use it. 😁
All_Moto
All_Moto
36
82
Kearney mo
I’ve had the hess bypass for a year. I never had a bit of diff problems till shortly after installing the locker. Could be coincidence. I ordered a complete front differential and clutch assembly. I don’t have time to take mine apart and fix a specific issue. I’ll put the new diff in, so I can make a crawling event in a couple weeks. Still fix the original so I’ll have w spare. I’ll try upload the video of it engaging and disengaging. Sounded sketchy with the turbo at the rev limiter doing cyclones 😆 figured if it was gonna break it would break. Guess it did 😆😆 Oopsie
  • Haha
Reactions: CID
All_Moto
All_Moto
36
82
Kearney mo
Complete front diff came in, and had time to pick it up. Pushed snow for 30 hrs, taking today off work. Pulling front diff now. Will see how original clutch and diff look, but trying to decide if I should swap the whole unit, or just the clutch. Not sure if I want the locker or not now. Coincidence maybe, but never any issues till put the locker in
PaulF
PaulF
1,462
4,817
Oh, I don't know, maybe this had something to do with it :) ?...
All_Moto
All_Moto
36
82
Kearney mo
It was already broke at that point, I’m sure it didn’t help 😆
if it’s just the clutch, makes me wonder why it went so fast. I’m not real familiar with them. Yeah his project will be knowledgeable
  • Haha
Reactions: CID
All_Moto
All_Moto
36
82
Kearney mo
Seems the clutch tries to work, just won’t hold. I’m guessing was engaging when there wasn’t much load, and wasn’t holding when there was more traction
60684552 8E75 41CF B80C A99BD8A4E707
Reactions: SLOWPOKE693
