Talon Extra Electrical Wires
68,345
That’s where I was planning on putting mine. Just wish mine was here. I’d help you find anything out.
Some step by step install pics would be great.
Would like to build a basic how too.
I can add the text. Just need good pics.
Reactions: BWAF
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
I get mine back April 28, leave for takeover the 30th. May not be able to for a while.
Reactions: Hondasxs and BWAF
68,345
That's where they want the horn switch mounted, see the instructions posted in this thread.
Honda has you cutting a 3rd hole for the horn. Still leaving the switch hole in question open.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
Yes!
I heard there was a green Talon in there shop ,you were 1st that came to mind .Good guys do nice work I ride with them some up here.Shop is like 8 miles from house.
Reactions: my99svt
my99svt
my99svt
1,267
5,248
Keep on them, I need that done for takeover!
They do great work. I’ve been seeing their cages all over the place and they look awesome!
Reactions: BWAF
BWAF
BWAF
8,869
42,496
Carthage MO
Bigblue1
77
92
NC
I'm fairly sure that is where honda wants the winch swirch to be. But still awaiting confirmation.
I have the winch install kit and it doesn't come with a switch and I talked to the Honda tech at my dealer and he has already installed one and he said it didn't come with a switch.
Reactions: Hondasxs
68,345
Where do u get the winch switch from then?
HondaTech
Again all an assumption here, but I'm guessing it's like the P1K and P700 kit which only comes with the wired remote. There might not be a rocker switch.
68,345
I didnt know that on the others.
Your most likley correct then.
Thanks.
Bigblue1
77
92
NC
The kit only comes with the wired remote and doesn't have any connection for a switch, Honda tech said it only works with the Key on . He also said that he drills a hole in the inside of the glove box on the side.
Reneb3
46
24
Cross sc
I used a KFI switch and grafted it into the remote harness. Green to green, black to black, red(KFI) to white. The KFI white goes to ground for the light. Works fine, I didn't like having to fiddle with the remote. I mounted the switch in the switch plate so the passenger could reach it.
rbtnt
rbtnt
76
61
Reneb3
46
24
Cross sc
It is, I just cut the wire to the right length. I had to de-pin the connector that came with the switch so I could thread it though the round hole for the winch remote. So my final harness had the winch remote and the KFI connector both going to the three pin connector that plugs into the sub-harness. I soldered the whole thing up outside of the machine. Works well.
