Talon fighter from Kawasaki the KRX?
272,156
This just got posted a short time ago. Patent from Kawasaki sport SXS.
Screenshot 20190221 055250 YouTube
272,156
Here is the actual patent ....
  • Kawasaki-side-by-side-patent-US2010202151.pdf
Reactions: Plumber32 and sharp
322,690
Looks very interesting. Too bad on the cvt aspect
Reactions: Chooglin
322,690
I don't understand why so many brand/models have stuck with the CVT , is it cost ? Why haven't they changed to gear transmission? Isn't Yamaha the only other brand doing this in the sxs's ?
Ya so far it’s only those two. Rumor mill Polaris is working on something but I really think there will be others shorty.
It really looks kawi is belt, surprises me with an all new machine that’s coming into Jap market against Yami and Honda. I suspect it’ll either beat them with power/build or price point to stay competitive.
272,156
In the patent it specifically refers to CVT transmission, from speculation on tfl off road, they say engine looks to be a 3 cylinder inline setup if the drawing is accurate.
69,050
There really is a lot of benefits to a belt drive. Easily adjustable for tire size with about $20 worth of weights. You can achieve more wheel speed in deep mud and snow. Yes maintenance is required, but its Usually pretty easy.
322,690
Biggest benefit is manufacturing cost. That’s why it’s still done.
69,050
If I were to buy a real sport machine I'd go belt without a doubt. These geared transmissions don't have a proper low range. Our pioneers would be better if they had the Yamaha wolverine transmission. Don't get me wrong grabbing gears is fun, but a proper cvt like the Yamaha with a 10yr warranty would make this rig better.
322,690
Yami does a night and day difference on belts and would actually consider one again after the clutch setup in the Wolvie but man I like the gears! Like them so much the truck and the motor home now have them lol.
Very curious if the kawi will run a clutch setup like Yami. Could be an incredible machine and worth looking at for some. Jap rigs are coming hard, going to get interesting shortly
HondaTech
All the low range is any CVT is a switching to different gear set or a single gear.
I've been in a Teryx/Brute Force trans, their just a shift fork that moves a gear set.
The P1Ks sub trans is basically a CVT trans attached to a 6 speed constant mesh. If the P1K doesnt have a "real" low gear than neither does any other UTV.
69,050
I'm no tech don't get me wrong. But every cvt sxs I've driven the low range was lower than the 1000. It can crawl at 2-3mph.
HondaTech
It would appear the drawing shows a parallel twin under the bed instead of their V-Twin.
Would need to be a clean slate then, since Kawi doesnt have use a parallel twin in anything thats belt driven.
HondaTech
They operate in the same principle, the final drive or gearing could be lower. Putting the P1K in low it should crawl downhill. The belt drive does help smooth low speed throttle inputs, whereas the dct engagement makes slow speed crawling jerky.
But the clutch update seemed to help that aspect out in the units I've driven.
