For a while, Ive wanted to increase ground clearance without portals because... $.
I recently found a lift kit that uses front and rear brackets instead of spring spacers. This lift is accomplished by changing the spring/control arm geometric relationship. I understand that the change in geometry also changes the spring force exerted on the control arm and other suspension geometries. I would like to know the change in spring force so that I can make an educated guess on how the car will ride differently - in this case, how much stiffer.
Its been a long time since I've attempted calculations like these so it might take me a while. So before I begin... I'll ask: has anyone here performed similar calculations? Are you willing share them?
For reference, here is a picture of the geometry change (shock angle change is approximately 8deg):
