Talon Seat Risers and Cab Heat Solutions
F
Fyathyrio
237
657
Don't forget the Jeep CJ Dana 20 shift boot trick on the Talon shifter, that reduces a bunch of hot air pouring in.
The DEI kit is not hard to install, and does reduce much of the radiant heat around the floorboards and lower tunnel.
TerryH
TerryH
664
2,241
Springdale, Ar
I thought the DEI kit did a pretty good job of heat mitigation personally. It does have a large fiberglass and foil covered self adhesive panel that goes on the panel behind the passenger seat. The Jeep shifter boot mod is the one that is truly worth it's weight in gold. Crazy how much heat come up thru the shifter hole. The boot virtually eliminates it.
lowranger
lowranger
459
2,506
Northern California
I did the Jeep shifter boot on Terry's recommendation and it truly does work in keeping a lot of that heat out.
TerryH
TerryH
664
2,241
Springdale, Ar
OK so I had to try the seat spacer deal. I cut 2 pieces 1.25" long from some UHMW PE Plastic Rod that I had left over from another project. Quite an amazing difference. Test it out more this weekend and decide if I want to try spacers on the rear of the seat also.
IMG 9969
IMG 9970
IMG 9971
320,218
Reactions: TerryH
scottkooch
scottkooch
65
233
SO MN
  1. Talon X4 LV
Terry, if Mrs. Terry is anything like my wife, you better do her seat as well. She didn't like that I was sitting higher then her.
