I do not, but it's happened to a lot of us. There's a thread or two on upgrading that issue so it's a little easier next time you need the bumper to come off.
I think I broke one of the same bolts the very first time the bumper came off for wench install. I drilled out a bigger hole and added bigger/stronger bolts with a welded nut from the inside. Went ahead and added recovery hooks to the same bolts as that's about the strongest point up front. Either way, sorry I can't quite help ya on the tap size, good luck Stone Man 👍
