P1000 Tap size Front bumper?
GRANITE
GRANITE
People Dying to come see me!
1,627
9,515
Brookville, Indiana
Somehow I’ve stripped bolt and need to retap the nut! Anyone know tap size/thread of the lower bigger bolts on front bumper? Thx
9B02A2AB 89E4 4E2E A871 A4074480499B
JenElio
JenElio
82,265
714,720
Loxahatchee, florida
I do not, but it's happened to a lot of us. There's a thread or two on upgrading that issue so it's a little easier next time you need the bumper to come off.
20200731 2352092
I think I broke one of the same bolts the very first time the bumper came off for wench install. I drilled out a bigger hole and added bigger/stronger bolts with a welded nut from the inside. Went ahead and added recovery hooks to the same bolts as that's about the strongest point up front. Either way, sorry I can't quite help ya on the tap size, good luck Stone Man 👍
GRANITE
GRANITE
1,627
9,515
Brookville, Indiana
Thx buddy! Hope all is well down in Florida!!!
21,741
93,133
M6 x1mm and m8x1.5mm should fix you up.
Reactions: JenElio
P1K5Dave
P1K5Dave
2,330
8,690
Petoskey, MI
I can't remember whether it was the uppers or lowers, but I wound up just drilling them out so the welded nut was just a pass-thru.
Then I used new, longer bolts with a new nylock.
Just-Snake
Just-Snake
6
Iowa
Took my stripped one to Home Depot and found this. It worked.
20250403 174143
Reactions: CID
