P1000 Tap size Front bumper?
JenElio
JenElio
82,912
718,493
Loxahatchee, florida
Somehow I’ve stripped bolt and need to retap the nut! Anyone know tap size/thread of the lower bigger bolts on front bumper? Thx
I do not, but it's happened to a lot of us. There's a thread or two on upgrading that issue so it's a little easier next time you need the bumper to come off.
20200731 2352092
I think I broke one of the same bolts the very first time the bumper came off for wench install. I drilled out a bigger hole and added bigger/stronger bolts with a welded nut from the inside. Went ahead and added recovery hooks to the same bolts as that's about the strongest point up front. Either way, sorry I can't quite help ya on the tap size, good luck Stone Man 👍
GRANITE
GRANITE
People Dying to come see me!
1,627
9,515
Brookville, Indiana
Thx buddy! Hope all is well down in Florida!!!
21,765
93,380
M6 x1mm and m8x1.5mm should fix you up.
Reactions: JenElio
P1K5Dave
P1K5Dave
2,336
8,719
Petoskey, MI
I can't remember whether it was the uppers or lowers, but I wound up just drilling them out so the welded nut was just a pass-thru.
Then I used new, longer bolts with a new nylock.
