P1000 Terrible pull and handling.
Herkloader1
27
132
Montana
So my 2022 100-5 completely wore out my original front tires in under 500 miles.
I pulled the trigger on a nice set of Tusk tires.
It immediately started severely pulling left on me. The tire shop did not get the bead set on two of my tires. After fixing this, it seemed to do ok other then a grinding noise when I turned.
Turned out they swapped a back and rear tire in me. Got that fixed and the pull was back.
Everything is tight and air pressures are good.
The thing also acts like a death wobble on a F350 truck at times.
I am at a loss as I only have about 600 miles on it and it has all been pack trails ,old logging roads.So no ruff riding.
Any ideas on what could be causing this?
I cannot afford tires every 500 miles.
5,492
25,268
Check your toe-in. Honda seems incapable of sending them out with both front tires pointing anywhere near the same direction. :mad: Any toe-in is better than toed out. 1/8” to 3/16” should get you in the ball park. Someone with the actual spec should be along in a minute.
115,818
So my 2022 100-5
Never heard of a 100-5 🤔 😂
Welcome from Michigan!
Seen you joined today. Glad to have ya! When u get a chance start an Into Thread and tell us about yourself and post some pics! As we say….
Pics Or It Didnt Happen!
And of this tire ware!
Herkloader1
27
132
Montana
20220810 143348
Herkloader1
27
132
Montana
It had maybe 5 miles of pavement driving. The rest where old hard pack trails ,like old logging roads.
The severe pull started after I put the new tires on it. I went with the Tusk tires because it is a harder compound then the factory tires.
It may be just me but they seem like the front tires point in different directions.
Just trying to figure out why it pulls and sometimes feels like a wheel is coming off now.
Rayger143
Rayger143
3,131
27,478
Winfield, BC Canada
For your tires to wear like that on non blacktop surfaces I would think there is something very wrong. Way out of alignment or something broken or very loose. Should be obvious I would think.
Bighat
Bighat
887
3,795
Gallipolis Ohio
Looking at the picture the tire seams to be wore flat. I just set the toe on mine because at 1700 mile the inside of both tires are wore. Toe was out on mine. Are yours wore on one side more than the other? I can't tell from the picture. Here's what mine looks like.
1667898288872
DRZRon1
DRZRon1
1,247
3,975
PA
suggestion
-get each side up off the ground and check
wheel bearings
a arm pivots
ball joints
shocks leaking
suspension hardware
dare to say - tire balance
check rotor bolts - they have been known to back out
by chance did the calipers ever get removed and are rotated pinching the brake line
check for stuck caliper piston
then onto alignment
