Multi The Honda Part Number System.
66,869
Last few days I have found myself researching the Honda Part Number System and figured I would post the information for everyone here to learn about as well.
General parts:
YYXXX - XXX - XXX(XX)
YY = Function Number
XXZZZ- XXX - XXX(XX)
ZZ = Component Number
XXXXX - YYY - XXX(XX)
YYY= Parts Classification Number
(These numbers relate to the Product Code of the first Honda motorcycle model to use a particular part; if the same part is subsequently used on another model, the Parts Classification Number generally remains unchanged. Some of these numbers are listed here. For more information, see the Parts Interchange Info page.)
XXXXX - XXX - YYX(XX)
YY = Modification Designation
XXXXX - XXX - XXYXX)
Y = Subcontractor Designation
XXXXX - XXX - XXX(YY)
YY = Color Code (if any)
(Part number color codes do not necessarily correspond to the Honda motorcycle paint codes listed here; they are keyed to the Honda paint codes listed in the relevant Description section of the Parts Catalog.)
Bolts, nuts and other standard parts:
YYXXX - XXXXX - (XX)
XXYYY - XXXXX - (XX)
YYY = Type Number
XXXXX - YYYYY - (XX)
YYYYY = Dimensions
(Dimensions of many common parts are reflected in this section of the part number—see Dimensions below.)
XXXXX - XXXXX - (Y)(X)
Y = ISO Standard Designation (if any)
XXXXX - XXXXX - (X)(Y)
Y = Chemical Surface Treatment (if any)
Common abbreviations:
ASSY. Assembly
COMP. Complete
R. Right
L. Left
STD. Standard
MM Millimeter
G Gram
T (22T) Tooth (22 Teeth)
A Ampere
V Volt
W Watt
WL With labeling
WOL Without labeling
KPH Kilometers per hour
L.E.D. Light emitting diode
MPH Miles per hour
L (100L) Link (100Links)
A.C. Alternating current
D.C. Direct current
IN. Intake
EX. Exhaust
FR. Front
RR. Rear
HEX. Hexagonal
A.M. Attaching mark
T.M. Transcript mark
C.D.I. Capacitive discharge ignition
Dimensions:
Parts Example Interpretation
Bolt (screw) 6 x 12 6mm diameter, 12mm length
Pin 8 x 14 8mm diameter, 14mm length
O-ring 9.5 x 1.6 9.5mm diameter, 1.6mm thickness
Oil seal 14 x 24 x 5 14mm inside diameter, 24mm outside diameter, 5mm thickness
Tube 5 x 130 5mm inside diameter, 130mm length
