Just so many possibilities! You know you guys really are bad influences and it doesn’t help that I am so easily influencedI know what you mean. Bought some crap last night for the stereo, just got done with the HMF and Dobeck, and have arched A arms on the brain.
-22 degrees today with the windchill and wires are too stiff to finish wiring up the lights so figured I’d address rattles in the storage box...
Before...
After...
View attachment 103475 View attachment 103476 View attachment 103477
I did about the same awhile back.-22 degrees today with the windchill and wires are too stiff to finish wiring up the lights so figured I’d address rattles in the storage box...
Before...
After...
Lol, that box rattle gets old after a while! I still may remove the two upper hinges if it rattles or try some adhesive backed rubber straps. Although it may be nice to have the ability to secure your gear while away! Any way those were my thoughts when I considered placement. Nice job on yours! I didn’t consider mounting like you did on your upper mount but I like it!View attachment 103556 View attachment 103557 View attachment 103558
Each sticker represents a mod which was installed! I applied all of the stickers just prior to Takeover ‘17! Of course I had more mods than stickers even then and haven’t applied anything since! I do have a plan for the looks of the mini BEAST, but that project will not happen until spring-summer and will limit the amount of stickers I am able to install. I do believe in personalizing and setting my build apart from others! But really I can’t wait to see what I come up withSome guys are adamantly opposed to having any stickers on their ride, I have a ton of stickers in and on my machine. What's funny is I have a pile on the bench that's way more than what I have put on.
Yes sir I am! It is the only way to test the new ability of the mini BEAST. I will hook up the winch for sure and grab some straps because I do intent on getting her stuck again. I say if you not getting stuck your not trying hard enough.you going straight for the same spot as the other night?
I am going to say it will plow right through that snow now.........easy peasy!Yes sir I am! It is the only way to test the new ability of the mini BEAST. I will hook up the winch for sure and grab some straps because I do intent on getting her stuck again. I say if you not getting stuck your not trying hard enough.
