P500 The P500 that Dubbs Built (or is building)
DaddyDubbs
DaddyDubbs
14,772
139,314
Got my 2017 P500 in early November, the build is on
So far I've added the following, in not the most logical order...
Moose folding windshield
Strong-Made Front Bumper
EMP Aluminum Roof
Maverick Rear view mirror
Traveller (Cree) {TSC} 15w LED work light - Rear
Traveller (Cree) {TSC} 36w LED Light Bar - Front 7.25" [Got the camo light because it was clearance priced $30.00 off ]
FrontLED01 Front light bar mounted in garage, Winch to follow and mount below light bar.
Front04 OEM OEM lights only
Front04 Both With the CREE lightbar added - Actually it's a much better depth of field than what is shown here.
RearLED04 15w rear work light mounted
RearLED01 Output of rear work light
rocmar
rocmar
4,741
5,776
4 CORNERS
Kool....
love the camo
AlR
AlR
470
1,166
Nanaimo, British Columbia
Love the camo color. I opted for 30" led bar on the front. Can't go wrong with cheap Chinese. I put two cube leds pointing forward but 45 degrees to the sides. That was a very handy addition for trail riding. You can never have too much light!
Al
2017hondapioneer500
2017hondapioneer500
Florida
Hi, I can't find the Moose folding windshield for my 2017 P500. Where did you buy yours and are you happy with it.
DaddyDubbs
DaddyDubbs
14,772
139,314
Sorry about the delay in reply. I actually purchased the Moose windshield at time of purchase from my dealer. Attaching to Pioneer is very easy. While installing my winch I moved the windshield up a bit so I could remove front hood easier (which may also help with dust vortex). However not quite as secure in the folded position. So far I do not have any complaints. You can look at www.mooseutilities.com and go to dealer locator with your zip, even if they have to special order it should be shipped free to dealer. Good luck.Moose1 Moose2
Reactions: 2017hondapioneer500
DaddyDubbs
DaddyDubbs
14,772
139,314
Finally got photos of the winch installed. I got a good deal on a Superwinch LT4000ATV SR so a little overkill but should work just fine. Also got the KFI hook stopper and snatch block. Finally a Hi-Lift STRP-315 3" x 15' tree saver recovery strap. I mounted both the fixed switch and remote plug in on the left side dash under the cup holder.
Winch1 Winch2
2017hondapioneer500
2017hondapioneer500
Florida
Sorry about the delay in reply. I actually purchased the Moose windshield at time of purchase from my dealer. Attaching to Pioneer is very easy. While installing my winch I moved the windshield up a bit so I could remove front hood easier (which may also help with dust vortex). However not quite as secure in the folded position. So far I do not have any complaints. You can look at www.mooseutilities.com and go to dealer locator with your zip, even if they have to special order it should be shipped free to dealer. Good luck.View attachment 39481 View attachment 39482
Thanks for your response an I will check out you links
2017 03 24 001
Reactions: 100Acre
