P1000 To groove or not to groove
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
They do look great. Give the wheel manufacturer a call and see what they say about the gap. Is it really 1/4"? I agree you definitely want it tight to the rim. Not sure what the best solution is.
Ok so tires and wheels mounted and on .No grooving as of now want to do some testing. But wanted to update everyone. Ok the beads on truck tires are thick I'm pretty sure I'll half to make 1/4 spacers to go in between beadlock and wheel and get longer bolts as of now the Rings are not torqued to the rim only to the bead of the tire. There's still room in between the lock and the rim I don't think that's right.But overall pretty happy so far .If I had to do it again @Cuoutdoors dont know if I would have gone beadlock but,they look awesome.View attachment 73904View attachment 73905View attachment 73906
Reactions: BWAF and Ragnar406
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
I'm sure they would just say they are ment for utv tires
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
That's very possible but maybe they have a solution. Most guys in the Baja 1000 run truck tires on their utv's and use beadlocks. What are they doing different?
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Good question
Neohio
Neohio
Beast of the East
17,836
86,038
Painesville Ohio
There will be a gap between ring and wheel. I thought the same thing...but it is normal. Just make sure they are torqued to the wheel manufacturers specs and roll with em!
For proper thread engagement, I would suggest acquiring bolts 1/4" longer than the rims were delivered with.
Reactions: GPR1500SC and BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Ok so reading, research and I have buddy that has factory beadlock on rzr rockcrawler. Beads are to fat so here's what I did to them before I make solid rings it was pulling so hard the bolts weren't straight/ perpendicular to rim any more! New setup .04 taper in lock ring with .326 nut behind ring . Old setup .180 taper not touching rim. Be61b6d8778c6bc1de90e0f3732fe701new 880f0c3adcb1a93f72292a4e71b0e519 old 0c44066c484dd91ef8bbc197ffac03d29024eac3c76e246875964f4e4d199565
BWAF
BWAF
8,864
42,478
Carthage MO
Ok well I grooved it's like picking at a scab once you start hard to stop 4ee88078d91ca0efd8c2800c766f41f2I'll probably do inside lugs too 6a6238c64fe48725d8e352be37abc911E6c93101cc6ae709587c10d6d50f1288
Mudwing
Mudwing
36,959
306,672
The Mud holes
I think you’ll definitely get better grip!
Reactions: BWAF
I
Ice
wisconsin
So going with light truck tire but thinking about opening them up some more for rock cliff's and what not as far as trail riding. Dont do the mudding .The white is what I was going to cut out.View attachment 73037Stock View attachment 730381st option View attachment 730392nd option. Looking for some feed back
Well in the ice racing world more little edges give more flex and grip from my experience. More open tread is for more clean out. So i say groove away but think about sipes.
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Went with op1 plus sipes
BWAF
BWAF
8,864
42,478
Carthage MO
Not done going to do inside sipes too 9e09a44724dcc91f0e2ed2169c6644f8Ea9fb249a195fddca4c2e390b70f44e6
