Does anyone use a mower that they tow behind a Sxs? We may be buying a new house in 4 acres. I currently have a lawn service and sold all my lawn equipment a couple years ago. I'm thinking about looking for a mower to tow behind my pioneer.
I don't have one but my neighbor does. They mow pretty close to what you are talking about with a tow behind a Kawi Mule (not a Pro FXT, one of the older smaller designs)and a Kubota tractor. They were doing it with an ATV a while ago and she said that it was really, really hard going that slow for that long. The Kawi seems to do it fine but the Kawi is designed to go slow.
I did some research before I bought my new mower here is what I found:
Pros-
-Don't have to keep up a mower
-Takes up less storage space
-Could get seat time on my ATV (at the time)
-Cheaper than a mower
Cons-
-Going that slow for that long could overheat an ATV (I don't know about the Pioneer)
-Going that slow on an ATV was very hard on your thumb (maybe leg cramps on a SXS?)
-You can't back them up without potentially damaging something
-You have to start and keep the mower deck running and sometimes it will shut off and you don't notice until you turn to come back
-You can't get real close to things so you will need some type of a finishing mower/push mower/trimmer to finish up close to stuff
-The really nice ones are nearly as expensive as a good quality mower
-The cut quality leaves a little to be desired
If you have 4 acres to mow, I would probably go with a commercial quality zero turn. If you have hills or pretty much anything that isn't extremely flat land, make sure you buy something with a good high quality serviceable hydrostatic transmission. Hills will ruin big box store mower transmissions in very, very few hours based on my ruining 2 lower quality mowers before figuring out what was going wrong.
ETA:
However, I have been thinking about this again since I also now have a SXS instead of an ATV, so I would like to get more seat time/reduce the garage space needed.
If you do decide to get one, please keep us informed on how it works for you.
