trail armor skids plates
Mollie46
69
86
AZ
Anyone have any tips on installing trail armor skid plates, I see that there a lot of self tapping screws that need to be installed on the 1000-5 Pioneer?
Reactions: BWAF
TripleB
TripleB
12,113
103,350
Caryville, Tennessee
I just followed their instructions. I used 4 car ramps to make it easier to access. Other here tip it on its side with a winch or something. Replacing the self tappers with nutserts would be better. I've had to replace almost half of mine in 1.5 years I've had the skids. Dont over tighten them, I stripped out 2 self tappers on my 5 seater and 1 on my 3 seater.
Reactions: BWAF
Mollie46
69
86
AZ
Reactions: BWAF
TripleB
TripleB
12,113
103,350
I would suggest weldables if that’s in your wheel house. The nutcerts have a tendency of spinning
What he said. I used some out of an assortment kit off of Amazon. I bought the tool there also. I've had some spin and had to redo them. I cant weld worth a s*** or I would go that way also.
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Put the side rail stiffeners on to prior to the skid plate I wish I would have known about them when I before I put mine on
Mollie46
69
86
AZ
What side rail stifferners are you refering to? I have made my order but have not received the kit yet, scheduled for next week.
Reactions: BWAF and Ragnar406
Ragnar406
Ragnar406
The Great Bald One
4,446
17,026
Bella Vista, AR
Some people have used these and welded them on others have used some Angle Iron and bolted them on like here in post 8
trail armor will stick about 1/2" further out than your side tubes
Mollie46
69
86
AZ
With the stiffeners you would have to weld in place and I'm not a good welder,can they be held in place with self tappinig screws without interfering with the Trail Armor skids?
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
I think I would go with the angle iron protects it two ways plus it just bolt right in
Mollie46
69
86
AZ
I would like to know how and what method did you bolt the angle iron, photos would be nice.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Screenshot
Screenshot 20191122 162801 Samsung Internet
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
If you're using nutserts, drill the hole with a unibit rather than a drill bit and you'll get a better fit. You want a tight and round hole for a good crimp. I haven't had any spin and I've had to extract 4 or 5 of my bolts after breaking the heads off wheeling
If you're using nutserts, drill the hole with a unit rather than a drill bit and you'll get a better fit. You want a tight and round hole for a good crimp. I haven't had any spin and I've had to extract 4 or 5 of my bolts after breaking the heads off wheeling
A unit??
Reactions: BWAF and Mudwing
