P500 Trail Tools
103,561
I'm sure everyone carries recovery gear but what extra tools do you bring on the trail with you? Spanners sprockets and wrenches, what do you carry beyond your winches? Do you bring air compressors or cans of fix a flat? Hi-Lift, Scissor or Bottle Jacks. Without overloading your ride, what do you think the most important tools to have are out on the open trails and what do you store it all in?
157,664
I consider GPS a tool. Mounted bottle jack, pressure gauge, tire plug kit, bottle of slime, air compressor, lithium ion jump starter, rain gear, bug spray, ball hat and gloves, flashlight, multi purpose tool kit and small first aid kit. A few zip ties. Other than recovery stuff, I think that's it.
103,561
Is there any benefit to Slime over fix a flat, and do you not use Quad Boss? I have a Delorme InReach GPS I'll be using. I didn't think of rain gear. Makes sense to get some rain pants maybe..Jump starter is a great idea!
157,664
I wouldn't think so, just want something to plug the hole if I can't find it. I use a Bestek jumpstarter, Amazon like $60. NOCO makes a nice one too. My first trip out I forgot bug spray and it sucked!
103,561
Do any of you guys use some type of MaxxTrax? Those are the orange things in the back seat. they can be used for traction in sand mud or snow. I've used them in different scenarios involving my truck and tractor. Could be used a bridging device too.
IMG 0161
AlR
AlR
470
1,166
Nanaimo, British Columbia
I recovered a quad off my brother last weekend. It is important to carry a little come-along. A winch doesn't work pulling something sideways, or when the rig is upside down or threatening to tumble further down the hill... been there, done that.
Multi - Three broken ribs
PS: good list Trig
Al
20170430 123429 HDR
157,664
PS: good list Trig
Al
Good idea! I have one in a case too that will probably fit in the toolbox...gonna check that out.
103,561
PS: good list Trig
Al
A come along for side pulling is also a great idea especially since I see myself traveling alone. Any recomendations for weight limit on one?
Reactions: cowboyjeff
AlR
AlR
470
1,166
Yes! I got mine for self-rescue. Get a small one. It'll rattle around in your tool box and take up space 99.5% of the time. A big one will just piss you off and you'll leave it at home. If you have a hard pull then just use a pulley / snatch block.
PS I carry a SPOT tracker around my neck when I go alone.
Al
Shadesmn
Shadesmn
505
959
Ramsey, MN
I can tell you from previously being a tire guy, fix a flat makes a mess inside your tire that sucks bad when you take it off the wheel. It "fixes" the flat, but also leaves a bunch of liquid inside the tire, which creates an out of balance potential for higher speeds.. I know that speed and p500 don't go in the same sentence, just sayin. As far as I know the slime sticks everywhere inside as opposed to just a tiny spot..JMO
103,561
Any knowledge of Quad Boss doing something similar?
Shadesmn
Shadesmn
505
959
Ramsey, MN
I've never seen the quad boss first hand, but i imagine it is the same as slime in that it coats the whole tire surface and stays that way vs the can of fix a flat. However if the fix a flat gets you back to the trailer, i guess the plus side is no need for a compressor too.. but i wouldnt leave fix a flat in a tire long term.
157,664
Don't know how long it takes to set up but I've put slime in trailer tires before, when adding air, green sh** oozing out of the valve. Couldn't imagine breaking that tire down at that stage, would certainly be a mess. Only plan to use it if I absolutely have too.
banjobart
banjobart
East Lansing, MI
I swear by the Dynaplug tire plugger. It only takes a minute and it has never failed myself or friends. You just push the plug in and pull the tool out. The plug stays in the hole. No reaming or glue. Plug the hole, spit on it and if it still bubbles add another plug. Twice I have used a row of four plugs to plug what looked like a stab from a knife. I have used the Dynaplug on my mower, wheelbarrow, pickup truck and motorcycles.
103,561
I'm looking to fill my tires with Quad Boss. At @Alan 's suggestion.
103,561
As far as a tire plug kit, I have the super awesome heavy duty kit by ARB. The plugs that come with the set are really thick. The tools are even better. Tough Stuff!
Tire repair
cowboyjeff
cowboyjeff
7
12
I have that same plus kit but made or sold by trail gear, it was about $12.00 5 or 6 Years ago.
Reactions: 100Acre
cowboyjeff
cowboyjeff
7
12
I carry a Snatch Block. a 30' foot 30,000 jeep tow strap, A very nice plug kit, a small Air compressor, and a half a dozen 99 cent disposable rain pants and jackets. Both my P-500's have 3500 pound winches on the fronts. I carry all this under the front hood, I have soda pop crates tied in under the hood, works great for anything that can get dusty or maybe even a little wet.
Reactions: CaboJim and 100Acre
