P1000 Trailer Question for the P1k-5
tdhanses
tdhanses
1,044
3,553
Kansas
Based on my tape measure it should fit easily in a 77x120 utility trailer, I’m looking at a Doolittle 7710. Thoughts, experiences and pictures welcome of a 6.5x10 trailer.
320,748
Be no problem. Straps will be a little tight on the ends is all.
annoyed
annoyed
86
282
USA
While I'm not familiar with that exact trailer, I'll give my $.02 for towing. My buddy and I both have pioneer 1000-5's.
He has a single axle trailer that is made of angle iron and wood (the brand escapes me). When we're driving, I can watch his trailer flex. His ratchet straps loosen frequently when we travel.
My trailer is a tandem-axle (overkill, but I use it for other stuff) made of C-Channel and wood. My trailer is rated for 7000# and has ZERO flex. I've never had a strap come loose.
My trailer is about 2' longer than his, which is nice for loading up with camping gear, coolers, etc.
FWIW.
tdhanses
tdhanses
1,044
3,553
Kansas
Yeah I have a 10k rated tandem axle hybrid utility/dump trailer that is 14ft long but it’s heavy and overkill for just pulling a utv. This will be a dedicated utv/zero turn mower trailer and I have plenty of bed space for gear. The one I’m looking at is a pipe top commercial grade with one 3500# axle.
I kind of ruled out the 12ft models just to keep weight down.
42D643BC 6C6F 476F BCF4 768A6C3126BF
Reactions: CumminsPusher
5,091
22,877
If you have room to park it, longer will pay dividends down the road.
The Talon is spec'd at 124" long, the Pioneer at 117", very close.
This is mine on a 14' trailer, room for a pit bike and camping gear/fuel/whatever. Looks like room to spare.
I mh7DwWD L
But this is where I'm at now, having added a bed extender/spare carrier, only a couple of inches between the spare and tailgate with proper tongue weight.
I d6qrBPV L
bluemountainbugler
bluemountainbugler
45
148
Walla Walla Wa
I looked at a lot of trailers and seemed like they were built pretty light. I settled on a PJ Trailer and had to order it to the specs I wanted.
It has a 12ft x 7ft interior deck which leaves good room. It has a 5000lb axle with electric brakes and heavy duty pull out ramps that stow under the right side. It pulls great and I have been very happy with it. For straps on the front I use the Erickson wheel straps/chocks,. They hold great. I found that regular straps were hard to keep tight for me with all the suspension flex and the less then smooth roads I travel.IMG 3825IMG 3826IMG 3827
Reactions: tdhanses
tdhanses
tdhanses
1,044
3,553
Kansas
Went and checked out the 7710 pipe top and was really impressed with how stout it is. They had a flat top or your traditional angle iron unit as well and you could tell it just wasn’t as stout or stiff. The rear gate on the pipe top also was way more heavy duty and has an easy lift gate system With a 5ft gate vs a smaller 4ft gate, also the smaller gate just had angle iron supports.
I could shake the smaller gate and it flexed a ton, the larger pipe top gate didn’t move.
Reactions: CMB
bluemountainbugler
bluemountainbugler
45
148
Walla Walla Wa
That's what I found too. Don't scrimp on trailer. Lots of $$ riding on it. I went with the optional ramps and no gate so it would be easier to use the trailer for hauling other things. That's why I liked the PJ because of all the options. The dealer let me build it any way I wanted. All the better trailer manufactures have a lot of custom features to get just what you want. Sometimes you might have to wait a little for it.
Reactions: tdhanses
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
I haul mine on a single axle Eagle Iron 14' x 7" W,
3500# Dexter axle.
Seems like plenty of trailer and pulls good too.
But doing the math; 3500# -less the weight of the trailer - less the weight of my buggy, pretty much comes to the rating of the GVWR axle weight.
So I bought larger 15", heavy load rated radial trailer tires and replaced the bearings with timkin for good measure.
Point being, understand your max GVWR and how much you are loading on it.
I will keep this little trailer but probably buy a tandem axle, electric break flat or covered trailer this spring.
Just sayin. Tow safe
tdhanses
tdhanses
1,044
3,553
Kansas
I want the gate, easier to load my mower with, my other trailer has the ramps and that made me decide on a gate for this one. I couldn’t get my mower on my other trailer, combo of ramps and height of the deck.
I was going to go look at Trailers Plus because their price is $400 less but more I look at their stuff and read up on them I’m not going to even look at them.
tdhanses
tdhanses
1,044
3,553
Kansas
I haul mine on a single axle Eagle Iron 14' x 7.
3500# Dexter axle.
But doing the math; 3500# - the weight of the trailer - less the weight of my buggy, pretty much comes to the rating of the axle weight.
So I bought larger, heavy rated radial trailer tires and replaced the bearings with timkin for good measure.
Pont being, know your max GVWR and how much you are loading on it.
I will keep this little trailer but probably buy a tandem axle, electric break flat or covered spoiler this spring.
Just sayin.
Yeah that’s why I’m going 10ft, all the 12 and 14ft trailers reduce actual usable capacity. Also don’t overload too much or your axle will fail before the tires. I’ll have more capacity in the bed of my pickup then the trailer 🤣
All I’ll put in the trailer is the utv, everything else goes in the bed of the pickup. You could put a 5k rated axle under your trailer relative cheap.
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
Longer pulls better, less bucking and feel of the road. JMO
Reactions: Coeus and CID
bluemountainbugler
bluemountainbugler
45
148
Walla Walla Wa
That's why I went with the 5200lb axle. If going single axle it is almost a must or yes you will be at gross weight. These 1000's are not too light. Brakes are a great option too. Don't want it passing me up.
tdhanses
tdhanses
1,044
3,553
Kansas
Yeah I may upgrade it later, it’s pretty easy to change them out. 5200 lb Axle TK Trailer Kit - 5.2K Capacity - (Original Series) but just the axle alone is around $200.
Yeah with a 3/4ton I’m not too worried about it passing me, now if total weight was 5k or more I’d get brakes.
tdhanses
tdhanses
1,044
3,553
Kansas
We’ll decide to just use what I have for now and use the funds towards shocks 😂
