P700m4 Transmission Service?
K
k9i449
CA
OK, I not very mechanical. So where and when do you service the transmission on a Pioneer 700-4? Nothing in the owners manual.
Please make it simple.
Thanks
Reactions: DG Rider
43,590
Thanks
You don't. It uses engine oil as the "atf". Just change the engine oil and filter and you're good to go.
Budman
Budman
118
322
Maple Ridge
Also change your diff fluid, especially if you are up to your axles in water often, it's cheap and easy to do. You don't need to do your diff every oil change, but it's a good habit. My two cents.
Reactions: swsebek
2nd this, check every oil change or more often if she's a swimmer. Change maybe once a year otherwise.
