P700 Transmission
Normjl
Normjl
5
Alabama
I own a 2019 pioneer 700 and I’m looking to service the transmission . Starting to have problems with shifting . It will be the first time transmission service. I can’t seem to locate what type of fluid it uses . I would like to change the filter too . I just need the types to use . Thanks
43,590
It uses the same oil and filter as the engine.
What type of trouble are you having?
Normjl
Normjl
5
Alabama
Thanks ! Sometimes the transmission doesn’t want to shift . I have read that it’s recommended to change the fluid every two years so it way over due . I have changed the engine oil every year and recently changed the front and final drive fluid . I’m thinking that because of the lack of transmission fluid change is causing my problem ??
Normjl
Normjl
5
Alabama
does the engine and transmission share the same oil and filter ??
Buggyman
Buggyman
47,988
376,356
ne. ohio
Thanks for the info . Does the engine and transmission share the same oil and filter ??
Yes it does. I run the Honda synthetic it seems to shift better than the regular oil in my opinion and have had no problems in little over 5000 miles. not much price diff. between that and any quality syn. motor oil.
Normjl
Normjl
5
Alabama
Yes ... the engine and trans does share the same oil and filter.
One of the reasons I like the P700 over the P1000 ... the P700 is a simpler machine ;)
Welcome from Ohio
Thanks !!! No wonder I couldn’t find any info on servicing the transmission lol . This info helps a lot . You be amazed at how much research I have done and I never read any mention of this .
Reactions: NewHere2
NewHere2
NewHere2
Village Idiot In Training
57,017
401,275
High Plains of SD
Always check the search for resources lots of step by step and material info there
P700 - Honda Pioneer 700 oil change guide
Welcome from Ohio
Yep ! What all those skilled and knowledgeable Hondacrats said !
Good luck !
thatguy2
1,002
8,286
Kansas
Everytime my pioneer had trouble shifting it was low on oil as it burned it like a mofo.
Reactions: Backwoods
