P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I thought I’d share some info I got from @nbomar about how to connect the Baofeng radio to the wetsounds stereo system.
This will allow you to use the radio as normal to talk to someone but it will interrupt your music and play the comms through the sound bar. I absolutely love it, I used for the Takeover all week and it was flawless. Volume is adjustable so I can hear comms at 50mph full throttle. Doesn’t matter if the radio is blaring or not.
The handheld radio is still mobile as it can be unplugged and taken with you if needed when you exit the vehicle. It’s still a weaker hand held and not a 25w unit but they aren’t bad and the extended antenna helps a lot.
You’ll need a BT receiver. There are cheaper but I didn’t want to mess with this again plus I wanted seamless connection to my WS sound bar.
This is the interrupter that Bomar told me about. There may be other options but I didn’t bother researching. This one works well.
The Baofeng radio has a 2.5mm out so I bought an adapter. Note this one is a 4 pole, not sure if it needed all 4 but I didn’t want to waste time. Same price as the 3 pole. I should also not that I wanted a flexible adapter and not the rigid version that would stick out 2”.
This is the above mentioned antenna. I keep it in the glove box, not sure yet if I’ll leave it on or use it when needed.
Just for reference here is the radio I purchased and spare battery. Not sure yet how good it’s going to be. It’s supposed to be a notch up from the GT-3P.
I bought that same radio and antenna. I'll get to test it out this week in Canada.
Dang HMF has cracked....
E13349c6a4fe263aeef09f5f2bfb488a
Looks like I’ll need to find time this weekend to pull it off and fix it.
I’ve also got an axle shaft seal on the differential leaking that will need to be changed outC25201bdc34e5292b1a270262172c6d9
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Of course I’ve had big tires since early 2016 so I’m sure that’s not accurate. Since early this year or maybe last fall I have had the gear reduction and the speedometer calibrators so it will be accurate from here on out
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Those are slow technical miles as compared to my 4,000+ hammer down 98% of the time lol! I honestly was expecting closer to 10,000:cool:
I’ve been so ashamed of my wiring job over the past two years and I finally convinced someone to give me a hand and straightening it all out.
Early in Travellers life the wiring job started out nice and neat and my intentions were to keep it that way.
This picture shows a lot of the accessories under the hood and it was still somewhat organized.
D77e941247fb8dce48b143684f13aed0
After too many late nights in the shop getting ready for a ride the following morning, I would add stuff to the pioneer in a lazy fashion. It went down hill over the past few years.....
12f9d2b3272d9a2412f55d5d28adb0f1
A370eb7dba9a813af754cdc055daaa1b
So I convinced @ohanacreek somehow to spend an entire day ripping everything out and putting it all back in nice and neat.
There is still a crap load of wires but at least there’s not a single butt splice or posi tap anywhere. Everything is soldered and sealed with heat shrink.
6e18c1d18cd397996dd77db3f5760d86
I had two switch panels before....
4887b559ca6029bd28794f64a99bb175
So now I have one panel and lost the AM/FM radio. This gave me back the cubbyhole underneath which now has four USB outlets and an extra 12 V outlet mounted flush on the back of it.
2849cfebff13c967eb57656b262ad008
This is what the panel looks like all the time with just a few things powered up so I can monitor battery voltage and see the power switch in the dark.
7e14c43987bac5e067a05f49b8ac8692
This is what it looks like with the power switch on
3f0bd121f9e2bd92658c34b86988c2c7
Here it is installed...
474da4126e5a29c898c9d39d145d609f
Ohanacreek was smart enough to wire my winch switches so that I only carry one wireless remote with one wireless receiver but it can operate both winches depending on the position of the winch switch.
He also helped me separate my four cube lights to where I can run the front pair or all four. That is the top left switch.
The top right is a switch for controlling the Blue Sea mLVD. This low-voltage disconnect will automatically break current to the auxiliary power distribution module to prevent the auxiliary battery from discharging. The break voltage is adjustable and you can override it with the switch if need to.
With the winch selector button in the neutral position, the “winch in” button will join both batteries manually for a self jumpstart feature if the primary battery is too low to start the vehicle.
We also added a SAE port next to the 12v socket on the fender for accessories or charging..
9d333640983e030af78e7d98493be13f
I hope it all works out good as I would hate to do trail side wiring. The next ride will be four days straight in the hills of Tennessee with a lot of night riding so everything will be put to the test.
One other cool thing is the headlight relay harness from @Hondasxs. I no longer have a switch on the switch panel for operation of the front light bar. It comes on automatically with the OEM bright light switch.
Here’s some info on the mLVD...368ff7db6bd6064bb6ca2a53f06f2f00
I sealed the factory air inlet to prevent water ingress to the mLVD
E6c99f85518c1c7642e2e3043e9d86aa
It mounts nicely in that little spot hidden under the horn
811846d9d5299dbf0c208e929acb8f66
I gave Walter at CreativeUTV graphics a few ideas and he come up with a cool sticker...
Contact him for several if you’re interested.
Man when you showed me that I didn’t know you were going to do a stick! I want one!
62,422
Damn that looks good. Mine looks like your 2nd pic... I don't have many accessories yet so I'm hoping to clean it up before TO.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Looks good man!
Similar threads
Hometeam
Replies
Views
2K
Hometeam
