P1000m5 Traveller II
Ac240df1c2fe35d8a8a5be85c6e90f10
39,079
Side mirrors now on. I don't like them as much as I did those pursuit mirrors but these were cheaper.
1a2a4d5f4592daff8e32f94dd5400276
A1d05d28b3c3cdcc9b985b092b2c02c4
39,079
Over head storage bag installed.
06325307acb7eabe001c3f1eed41fdbb
Reactions: Dp5hunter
39,079
265,439
Front and rear cup holders in the door.
1aece6cb1fa557d2b6a1f53b03283b2a
34dbf4436ad49cc7e504b1a65a4f38c4
Are those OEM HONDA parts or aftermarket? Where did you get them and about how much each.
39,079
Rocky Mountain ATV. Yes they are OEM and I think they're $7 for a pair. I looked up the part number for the 700 and they fit perfect.
Reactions: JTW and JACKAL
265,439
RMATV will not let you search for OEM Honda SXS parts, I tried the part # 08U70-HL3-A40 Still had no luck, when you have time can you check your order email from them for the RMATV item number they use? Much appreciated.
Your build is coming along quite nicely, keep up the good work.
39,079
Up coming parts on the work bench are stereo, fender flares, front and rear light cubes, dual battery and isolator, interior lights.
Things still waiting for shipment are bed liner, bed extender, front bumper, winch, light bar.
In the near future, forward arched A-arms and 30" EVO's
Reactions: ohanacreek
39,079
Almost forgot, skid plate when I figure out what to do about the front bash plate.
I'll probably get the Trail Armor and replace the front piece as a friend recommended.
39,079
Can't wait to hear how the lift works out.
I'm hoping to fit 30's with no lift. I'd like to keep a low center of gravity and fit in the garage. Not sure if someone will offer some
soon or it will be a custom job.
The High Lifter version may also lift the vehicle. Not sure as I haven't seen he details. I'm a little disappointed in my last HL purchase so I will approach them with caution.
Exactly what I want for same reason.
Reactions: joeymt33
39,079
Reverse lights mounted.
2af49f3c9534a4a75a0258aaeee923b0
39,079
Front light cubes mounted. I used flood pattern for the front and rear cubes. They will be used mostly for work and not needed for seeing long distance. The big light bar is for that.
I used the existing fender bolt for the light bracket.
B9a0d77f16afd1b5da0aa18172ff1898
It can be mounted to face forward or out to the side like I will keep it.
A64b1f38358e01b3f44353f9d764acf5
83207fad532a25a28bafbc2d372a7fdb
Similar threads
Hometeam
Replies
Views
1K
Hometeam
