P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
sharp
sharp
3,757
14,955
Tennessee
Check out my new invention, it's a bed extender for camping. I can sleep on it or use it as a table.
There's a guy out call @PioneerPete that thinks it's his idea but don't listen to him.
J/k buddy, thanks for the great idea!
Did you use the extend tailgate cables, or did you make a small bracket extension and use the factory cables. I'm too lazy to go back through your build. Lol
Reactions: pct
68,384
He added at extention. You can see it in the second pic.
This is a great idea. @pioneerpeat. I mean @joeymt33. I could see this easily becoming like those Jeep tents with full top and sides.
DGann
DGann
548
1,575
Russellville Alabama
Cool, if it breaks while you sleeping, I hope someone takes a pic because it will funny as all get out
I found some pieces of metal in the shop that needed no other modification. They fit perfect including the bolt hole size and length. And they are stainless!
I think I had about a dozen more. Anybody want one?
116,574
I can't remember the wire gauge but I had a roll of black lamp cord at the house. The wire gauge was larger then what came on the lights and lamp cord has a super thick coating compared to its wire size. Plus it's both pos and neg are joined so it made it look easy. I tied it along the roll bar going to the back lights and used some wire loom in locations where it might scrub.
I ran out of that wire and went to lowes and found more. I used a heavier gauge wire for the 40" light bar but those little lights don't need much. Also, everything will be fused so you shouldn't start a fire
SIGNATURE:
Quote by DrFubar: joeymt33, this could be your next signature: "I should be more understanding. I should know by now that a little hill to me probably is a big hill to you.;)"
Ware did you run the wires from the back lights? I ran mine along the roll cage. I'm having issues on ware to terminate them to get to the front. I was thinking down alongside the middle bar by the front door?
amc019
amc019
480
592
Little Rock, Ar
DIdn't I see somewhere that you had the Walker Evan's shocks on your rig now? Can't seem to find any installation pics.
I ran the wires along the top of the ROPS on the passenger side and then down the front bar by the windshield. I ran the wire thru the gap between the fender and ROPS.
Quote by jackal: "we won't be doing any extreme trails".
I borrowed the front only from @Hondasxs for a test drive. It wasn't easy but I get to test them for a month before sending them back.
I did run them last weekend and they felt good but I want to use them some more when I don't have 3 days of camping and riding gear in the back. That way I can get a good comparison of them vs OEM.
amc019
amc019
480
592
Little Rock, Ar
Pretty cool! I would love to see a shootout between them and then the Elka's. If Honda doesn't come out with a new SXS this Fall I might have to get me a set of either type within the next year.
Yep me too I'm not happy with the fronts. I was wondering as well Joey about a comparison. I just want fronts and to hear a report on that, you'd be a great guy to get that information from
AKRider
AKRider
1,402
3,225
Palmer, Alaska
I'm really close to pulling the trigger on the WE fronts. The Elkas are definitely less expensive but sound like a good deal. I really don't like the OEM fronts. I have a buddy that has the WE set all around on his Ranger and he loves them. They are pricey but they might be worth it. I have no issues with the rear self leveling shocks. I've never bottomed them.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I agree. Instead of a pop out camper, it'll be a pull out camper lol. Endless possibilities.
Reactions: joeymt33 and sharp
116,574
Quick question: referring to accessories you connected to the bussmann, where and what did u use for those grounds? I didn't see it in any of the pics. Tying to get ideas. Thanks
Reactions: CumminsPusher
They are grounded on my battery strap. I'll look for a pic.
Signature:
QUOTE by Eltobgi, Honda...Strong enough for the Farm!...Dependable enough for everything else!
206124f239e6ade209b3fef7a376d937
I used the bolt on the battery strap. In this pic there is just one ground but I have more there now.
It would have been cleaner to use a ground block with 6-10 lugs but I was to anxious to get it done.
Signature:
116,574
Signature:
Thanks. I was thinking that was what you did. But I was thinking a grounding block possibly. But at least that gives me an option if I get too anxious
116,574
That is exactly what I did. I jumpered all of my grounds and routed them back to a grounding bar that I mounted under the hood. I tapped the brown headlight wire and ran that to my switch panel. Then I jumpered all of the led backlights off of that. That way my switches are backlit when I have the headlights on even if the switch is off. I am a novice at best when it comes to wiring so you may get some better feedback from the other guys on the right way to do it.
I have a question, for some reason I'm having trouble with the brown wire from headlight hook up. Where is that location at that you picked that up from exactly? I'm having trouble following those ( could be that I'm tired ) but all I'm seeing when I'm tracing under the hood area is different brown wires with stripes. Is it a solid brown? Also my bussman should be wired to the auxiliary battery side correct? Or is that just a preference?
Similar threads
Hometeam
Replies
Views
2K
Hometeam
