P500 Trickle charger amp recommended?
L
Lookouttrout
51
185
Montana
For my P520 anyone know what the recommended trickle charger amperage should be?
Any recommendation to how run permanent charger wires off posts snd out battery box?
Thank you
HBarlow
HBarlow
1,614
6,004
Daniels, WV
Anything with the Deltran "Battery Tender" name is excellent. Can be purchased from many retailers including Walmart.
I have six or seven of them of varying sizes and power ratings. i use them on everything with a battery.
5,322
24,138
I like the Optimate series of chargers, they’re more expensive than the Battery Tenders but have a more sophisticated charging software.
Reactions: Jerryg
Mudder
Mudder
NTC Ambassador of Walls
11,605
87,353
Have a CTek smart charger, with dash plug ins or pig tails on SXS, motorcycle and tractor.
NTCPrezJB
NTCPrezJB
President of #NTC
106,017
943,957
Canton, OH
Thank you
Several guys have wired up remote "ports" (for lack of a better term) on the dash or similar that their trickle chargers plug into.
Gator
Gator
The Most Unknown Member
2,484
10,435
Louisiana
This one arrived at my house yesterday. I layed it in the sun and measured 20 volts. I hope that's not gonna mess up a batery.
K
kyote
66
241
La Porte TX
I haven't done it yet, but plan on mounting the trickle charger pigtail to the winch contactor under the hood.
L
Lookouttrout
51
185
Montana
Ah. Good idea. So is a 1.25 amp trickle sufficient?
HBarlow
HBarlow
1,614
6,004
Daniels, WV
Cheap so-called battery chargers and trickle chargers from ChiComm sources like Harbor Freight are a dime a dozen. They all fail quickly but will overcharge and boil a good battery quickly.
The Deltran brand use a mini-compuer to carefully monitor battery charge rate and battery voltage. They use a four stage charge process to maintain a battery fully charged but not overcharged. They can be left connected to a battery for months at a time without harm.
Your money, your battery, your choice.
HBarlow
HBarlow
1,614
6,004
Daniels, WV
L
Lookouttrout
51
185
Montana
The answer depends on whether it's a switched or always hot socket. it's probably always hot.
Does anyone know if the accessory socket on the 520 is always hot??? Thanks
HBarlow
HBarlow
1,614
6,004
Daniels, WV
The socket on my P1000-3 is switched.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,074
20,872
Route 66 Oklahoma
I use Battery Tender Jr on all my toys.
I have had a Battery Tender plus for about 8 years now, that has been in constant use, rotating it around on my P5 and 3 ATVs. Still going strong. I would buy another one, if it croaked tomorrow. The Battery Tender plus is 1.25 amps. All of my batteries are at least 5 years (or more) old.
bowhunterbill
bowhunterbill
420
1,300
Bozeman, MT
The 12v power port under the dash is only on when the switch is on.
On my truckle charger, the wires that connect to the battery terminals cone to a connector with a waterproof snap on cover. Thats where the leads from the charger connect- next to the battery box.
I left my P500 with no trickle chsrge in an unheated garage all Montana winter and it started every time.
Reactions: CID
