P1000 True battery isolator
Schmeg
Schmeg
187
394
Bangor Maine
Looking to pick up a true isolator with wiring from the store. Does anyone know if they are currently in stock? Heard rumors they may be hard to come by right now.
TripleB
TripleB
19,504
172,623
Caryville, Tennessee
I
Ordered 1 for my buddy on friday and received it 3 days ago.
68,146
All isolators are in stock and shipping within 1 business day.
Link if anyone needs one.
Reactions: CID and TripleB
BBB
BBB
273
1,344
Northeast Illinois
Mine came in 3 days also.
Reactions: TripleB
russknight
russknight
1,910
7,513
Perry Florida
How do they actually work? I have one that came with my used machine. Very high quality unit, but not exactly sure how they operate.
Reactions: Russ989
Russ989
Russ989
22,645
147,291
After starting the machine, the stator starts to put out volts of power to supply the system. As the voltage rises above 13 volts the isolator opens its switch and lets the excess voltage go to the auxiliary battery.
Reactions: Hondasxs
russknight
russknight
1,910
7,513
Perry Florida
Ok, but how does it actually isolate the cranking battery? Electronically?
68,146
When wired CORRECTLY it will disconnect when the voltage on both batteries drop to 12.7 volts or less. Thus isolating the second battery from the primary.
If you wire up your system for key-off use CORRECTLY you should never drain your primary battery.
Key word = CORRECRLY.
68,146
Also. The isolator has NOTHING to do with accessories or how they operate. It is only a draw bridge that connects and disconnects batteries at 12.8 volts.
What ever happens on the other side of the bridge is subject to your wireing job.
5,715
26,183
I'm about to buy your isolator kit ($119 on sale IIRC) for my Talon. What does the extra relay do, is it explained in the instructions? I think it plugs into the orange plug shown in the photo. I assume a wiring diagram is included? TIA
TripleB
TripleB
19,504
172,623
The relay allows the dual volt meter to turn on and off with the key. If there was no relay the volt meter would be on all the time. Which would drain both of your batteries.
Reactions: CID
68,146
BUT...
If your entire accessory system is AFTER a stinger or second battery relay setup like most, then you can eliminate the TrueAM relay and just put 1 line on the accessory fuse block and the other line on a key-on line.
