P1000 Ug, sucks in snow...
P
patpete
65
149
Alaska
Actually I’m running highlighter arched forward A-arms, I built brackets been running on them for 4 years
P
patpete
65
149
Alaska
Don’t know if you can see A-arms
A830C83F E8DE 423F B2C4 F4EC4FEE154B
Reactions: Rockydog
rickoshea
i still have a few years of warranty left on mine so it's staying stock for a while.
P
patpete
65
149
Alaska
My dealer here told me warranty still good they will warranty all but a-arm and bushings
P
patpete
65
149
Alaska
I don’t think you did. a-arms and bushings are after market they will still cover ball joints steering components and everything else. Plus when I change from tracks to tires and vise-versa I inspect fro loose or worn parts
P
patpete
65
149
Alaska
I built mounts for the front because I have highlifter arched/forward a-arms
rickoshea
keep in mind the tracks are HEAVY.it's a b!tch to do alone.uninstall is not so bad but doing the install by yourself is a pain.i have a hell of a time lining up the studs.that's what takes me the longest time.
P
patpete
65
149
Alaska
I’ll be putting mine on Monday or Tuesday I’ll let you know how long it takes me
P
patpete
65
149
Alaska
Started at 7:22 finished at 8:17 had 1 phone call and 5 text in that time, so 53 min unadjusted time I’m take a conservative time of 5 min for phone time so that puts it at about 48 min tires to tracks. Floor jack 17 &19 mm sockets for lug nuts 17 & 15 mm wrenches for a-arm mounts
9C19F294 7DA0 43FB A954 E0EEDC5C4486 357B041C 372C 4D73 A479 11D1A8808F6B C39BADF0 02B2 4A03 9089 B2B8DA34939A 49345E0D 168E 436D BADC 94036186B4FE
7:22 Pm. 7:48pm
8:17 Pm. 8:17pm
Reactions: Mudwing and TripleB
rickoshea
double check anything with height restrictions.mine juuust baaarely fits in my shop.i have maybe 3cm of clearance under the rollup door.i can't run a hard top,it won't fit, so i use the soft top in the winter. tracks and a hard top adds almost 30 cm. to the overall height.
