Hope to see pictures of that one day. You're quite industrious!For my auxiliary battery I mounted a flat aluminum plate then put a steel army surplus ammo box on top the plate under the hood.
Dropbox - P5 mods
Pending on your need you could fit different sized ammo boxes. Inexpensive very strong, I used steel nut serts installed in the frame and subframe to attach plate and box with grade 8 (1/4" by 20 tpi bolts).
Was thinking in time might look at sorting storage under the driver's seat using large ammo box on industrial drawer slides to pull out beside driver's door. There is a relatively huge space under there it's just sorting access and making water proof which fore noted would do. Just have to make a reasonable side door to access and mount rails.
jrc
That looks really nice, and inexpensive!!! Too bad they stitch welded the corners leaving it not water tight.Though I use the Lowes tuff box myself, here is a decent alternative that is cheaper than Honda..not sure if it's better but a great company Pioneer 500 Under hood Storage Compartment
I just bought this from extreme metal.we will see how it doesThough I use the Lowes tuff box myself, here is a decent alternative that is cheaper than Honda..not sure if it's better but a great company Pioneer 500 Under hood Storage Compartment
