The bucket had to be modified some to fit. After removing seat and side panel I measured about an inch up from bottom of bucket and cut bottom off. Then took bottom of bucket and put inside bucket like you are stacking buckets. Put a bead of silicone around inside of bottom of bucket so it would be sealed. Cut a notch out on top of bucket to clear rectifier and small piece so it would clear square tube were
Seat sits on make sure bucket is positioned so that side panel will fit back on before drilling two holes in bottom of bucket with a piece of rubber under a fender washer be sure to check under machine as to not drill into frame tube that runs under it.
