P1000m5 Update on dual battery install….
Status
Not open for further replies.
16Honda
16Honda
35
45
I'm back with some pics of my battery,lights,dash switches and stereo install.The side lights were on my Ranger a few years ago, so I wanted to use them again on the Pioneer. This project took me longer than I expected. I took my time trying to keep things neat and being careful making my connections. I ordered everything through amazon and had to wait awhile because shipments came from different places at different times. For all you that may be thinking of doing something like this, It takes a lot of thought because you run out of space to mount things pretty quick. I still need to tidy up some wires and find a keyed power source for the bottom lights on the rocker switches.
20151212 143234 20151212 143357 20151212 142826 copy 20151212 143451 20151212 143525
272,159
@16Honda Nice setup! Looks like a very clean install of the dual batteries and in dash rocker switches, props. Can you share some specific on exact battery used, isolation kit, sub harness, etc.?
For a keyed source for your rocker backlights there should be a black wire with white stripe coming out of your dash that feeds the cigarette lighter / accessory socket that should do the trick and be handily close.
16Honda
16Honda
35
45
Thanks, I have to say this was a lot of work I could of used 3 more hands for this job! I didn't use a sub harness, I made everything myself.I wish now I used a prewired harness. 3 of the switches came from
OTRATTW the other I don't remember.
links for the isolator,battery
Reactions: JACKAL
Very nice job @16Honda.
I'm glad I don't have my P1000 yet in a way. It gives me time to see what everyone else is doing.
Reactions: ohanacreek
16Honda
16Honda
35
45
Thanks, I'll take a look at it tomorrow.
16Honda
16Honda
35
45
Reactions: JACKAL
Calvin
Calvin
42
Benton, La.
Real nice setup 16Honda. This is the isolator I went with. Should be here Monday. Sry this is probably a stupid question but where did u connect common ground coming from isolator too?
Reactions: Zaldan
16Honda
16Honda
35
45
I connected the small ground wire to the small bolt just in front of the tool kit. It was going to be a temporary connection but it's still there. You can see it in the photo.
Calvin
Calvin
42
Benton, La.
Great thx for the info.
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
Anyone with ideas on what to use to hold the second battery in place?
16Honda
16Honda
35
45
That's the next thing I need to do.I haven't decided what to do for mine. My battery is pretty snug with the rubber around it but I need to come up with a strap to hold in.
educ8tedguess
educ8tedguess
403
972
  1. Looking to buy
I don't think it would take much but I definitely want to get something on there. Maybe a piece of flexible rubber with a couple of panel rivets (or whatever those things are that hold all of the plastics on...)
Jack39
64
31
Wareham, MA (near cape cod)
I don't have my machine home yet to see, but on other applications in the past, I have used rubber bungee's successfully for this purpose.
rcarroll
9
Here is how I made my strap it's just a hose clamp. I drilled holes and just ran clamp under plastic and around battery.
rcarroll
9
Where did you connect ground from second battery ?
sajnaj
sajnaj
171
146
clinton indiana
quick question couldnt you just wire the second battery directly in and not have an isolator .
272,159
Well you could but then you run the risk of draining both batteries to the point you cannot start your SXS engine, leaving you stranded. Same with an unexpected short. The isolator is valuable protection for your OEM electronic system. The old adage just because you can doesn't mean you should applies here.
Status
