I've got a 2016 Pioneer 500. I haul it on a 5x10 utility trailer which has a mesh gate, wood floor, and 15" tires. Bought P500 and trailer in June 2016. Trailer is awesome and stays right in line behind my 2018 Tacoma Sport 4x4. I never have any problems with the trailer and get the bearings greased every spring before starting riding season. Only problem - trailer is stored outside. Wood was treated with water proofing but is not painted.
I have 6 D-rings mounted in the wood floor and 2 on the front rail. I park P500 against front rail of trailer and run ratchet straps over each tire to strap P500 down. That way it never moves and most of my hauling is at interstate speed. Took a lot of trial and error and stopping and re-strapping to figure that configuration out, but it works like a charm.
Last spring, I could tell the wood floor was nearing the end of it's life. Last week, I found a rotten board. I suspect others are, too. Tomorrow, I'm gonna call dealer where purchased and get serviced to check on cost of floor replacement. I'm not sure if I want to go back with wood, or get a metal mesh floor or even a solid metal floor installed. Cost will have to be considered.
If I do wood again, I can easily reinstall new tiedowns in the new floor. Mesh would be even easier - no drilling. If I go with solid metal, I'll have to mark tiedown placement and then probably have dealer drill the holes, but here's the real question - do any of you haul or have hauled your P500 or P520 on a trailer with a mesh floor with D-ring tiedowns in the floor? Does the mesh support the machine's weight ok? How does the mesh hold up under the stress and strain of cranking the machine down against it with the ratchet straps?
I'll bounce these questions off the service tech as well, but wanted to see if anyone has any real-life experience with such a scenario and how it worked out.
Thanks.
Thanks.
