P1000 Valve Clearance
Jim1000
Jim1000
MN
Checking my valve clearance on my 2018 today. The intakes are 0.006 and all the exhausts are 0.0095. I am seeing 2 different exhaust numbers in some of the posts .009 and .012. Which clearance would be correct.
42,130
Another 1000 owner will be along shortly to give you the info, but in the meantime, Honda almost always puts valve specs and tune up info somewhere on the frame on a tag.
Reactions: ChadD
Mark in Northern Iowa
467
2,089
Floyd County, Iowa
kramnella.wixsite.com
In this service manual
pg 144, section 3-9 through 3-12
1646859468607
Have a good day
.009" Between the lobe and rocker
.012" between the rocker tip and valve
Manual has been updated to show the change between the old .012" and the now recommended. 009". Its same as the Talon.
20220309 180011
